3400 performance
  • gectek
    Banned
    • Aug 2006
    • 1472
    also another question, i had heard that some of the newer 3400s came with roller tip roller rockers, have u heard anything on this, or has anyone else?
    • Sidewinder
      • May 2006
      • 240
      I don't know that the 3100 has a large enough bore for the 3500 combustion chamber/gasket setup to work right. I won't guess on the power increase, but more than the gen 3 top end swap should be accurate Compression will go down unless you mill the heads. Its about 4cc bigger than a 3400 combustion chamber, but that also helps to explain the flow numbers.
      How much would it cost to bore out the engine and what else would it need? Or would it just be easier/cheaper to swap in a 3500?
      Edit: I'm and engine newb so I'm still trying to learn everything.
      Dual Outlet Exhaust with Resonator Delete, Front STB, Rear STB, GMPP Trailing Arms
      • 1988GTU
        LB62LHObbqftmfw
        • Nov 2005
        • 2475
        Since people can do 3.1MPFI/3x00 top end swaps (with custom length pushrods) , couldn't the 3500 top end be used also on the MPFI?
          • 13531
          Same problem as the 3100. The gen 3 heads were designed to fit the 3100, which is why I can get much better low lift flowumbers from modifying them to fit the 3400. The 3500 is already out there, so while I don't know for sure, i would avoid the 2.8/3.1/3100 and the 3500 top end combined. You can't bore a 3100 out to 3400 spec.
          The kit may come with an AFPR, or an option at least. Right now we just want something to clear the plenum so it doesn't have to be modified anymore.
          No stock 60V6 has had roller tipped rockers. The 3500 use the same rockers as the 3400 from what I can tell. I am not sure yet if the heads can be modified enough to fit the gen 2 pushrod guides, in order to use the crane gold race rockers that are roller fulcrum and tip. I have found studs to work for the 8mm 3400 heads (same as the 3500 heads), which started in 03 I believe.
          • gectek
            Banned
            • Aug 2006
            • 1472
            yah mine i think have the 10mm studs in mine, i think the redid the studs in 03. so they are the same ratio and everything then, will the 3500 heads come with all the vavletrain or will i have to get some new ones. and will i have to use the pushrods from the 3500 or will the stockers work or will i have to get special length ones?
            • Coinage
              • 16
              #21
              cam motion makes cams for the 3100/3400.. i am going to have a custom one ground for my turbo 3400 bottom end with 2.8 race heads..
              right now they dont have any cores in stock but maybe if they get more than one order, maybe they can get a few in stock a little sooner?
              • Sidewinder
                • May 2006
                • 240
                #22
                Although I didn't understand most of that, I gathered enough to understand that I'm boned. What can I do for my engine to get more power (aside from exhaust and FWI)? I don't want a stupid amount of power, but I want my car to be quicker than the average Lumina/W-Body. I'm thinking maybe around the numbers that the 3800SC puts out, or maybe a bit less because the 3800Non-SC is pretty quick by itself.
                I'm debating whether I want to boost or remain N/A.
                  • 13531
                  #23
                  The length is the same for the pushrods, though I would always check your geometry with any swap just to be sure. I also am not sold on the pushrods milzy sells. I will have a set soon but I am more concerned about strength than weight on the pushrod side. You want lightweight on the valve side.
                  I am not sure how the heads will come when I buy them so I may have to price new rocker arms. Hell, it might be a good time to just convince people to swap the whole engine. Its got a nice bottom end as well:P
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    #24
                    well yah if only it were that easy, ill try to sell a kidney or something so i can afford all that. what would the computer side of the engine swap really consist of?
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      #25
                      so are there any better push rods out there you recommend? and also would u recommend anything from milzy then if you dont like their rods
                        • 13531
                        #26
                        Well, their pushrods might be ok, i dunno yet. However its the length that needs to be checked. The ability to order custom length rods would be a lot better than only getting stock length. Crane does custom length but their tolerances are bullshit. There are a couple other places that make pushrods, though I am not sure on price and turn around time.
                          • 13531
                          #27
                          I am currently looking at the stage 1 kit from milzy
                          What would you pay for a 3500 swap ready engine?
                          • Rhedalert
                            Dr. Feelgood
                            • 1574
                            #28
                            *head explodes*
                            Brian
                            3400 SFI V6, 4T60e
                            • gectek
                              Banned
                              • Aug 2006
                              • 1472
                              #29
                              it depends on if i could get someone to buy my old setup off me, but i was lookin at a new 3400 engine for about $3100 so about that i guess, but would that include a new computer and what else would i need to retro fit besides that external trigger
                              • AaronGTR
                                boost lover
                                • Jan 2004
                                • 708
                                #30
                                Smith brothers make custom pushrods. www.pushrods.net Cost is around $120, turn around time about a week, and they have lots of options. I wouldn't say you really "need" upgraded pushrods though unless you are changing rockers or going with a bigger cam. Also you said you aren't sure about headers... I'll tell you right now you aren't going to make any decent power gains without them, no matter how much porting and part swapping you do, because the stock manifolds suck. They will always cause a restriction to gains from other parts. There are plenty of people using headers with no problems and no burned wires etc. That all depends on how good a job you do installing them, and it's not hard. Suck it up and get some.
                                '97 Grand Prix GT 3800 (sold)
                                Gotta love boost!
