Plenum design....
  • EspanolaGuitarista
    Visionary
    • Feb 2004
    • 254
    Plenum design....
    I enjoyed the article about plenum design. I am a sculpter and was think thinking about designing a one-piece out of clay and then making a mold of it in plaster. Then I would form it with fiberglass with thick flanges for ridgity. It would be tall and would need a 3 in. cowl. Like a high rise maifold. What do you think?
    • 9191
    I contemplated that idea a couple years back when I first started tinkering with a new plenum design. In fact, I had actually carved a new design out of a piece of foam so that I could fiberglass over it. Once it was fiberglassed, I was planning on getting something that would just dissolve the foam inside and then build up the fiberglass more. I ditched the idea though (can't remember why)....
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      That something used to melt the foam would be gasoline Does anyone know the side effect of doing this?
      • Cliff8928
        • 532
        PB Blaster also melts foam aswell... however the most efficient means of melting foam would probably be acetone.
        Cliff Scott
        89 BerettaGT
        89 Volvo740
        Cliff Scott
        89 BerettaGT
        04 AleroGX
          Visionary
          • Feb 2004
          • 254
          Melting foam?
          I don't think that is needed. You would have to create a 2 - peice manifold cast of the manifold. I was thinking a form could be made out of welded aluminum. Then fiberglass would be poured into it. I will continue later...got to run to take a job application.
          • Z2_4cams
            • 147
            napalm!!!!
            1989 Z24 3.1/3400 hybrid
            14.13@96.69 N/a slick full interior
            maybe my \"dreams\" should be a little higher :P
              Visionary
              • Feb 2004
              • 254
              Bringing up an old subject....
              Ok. I have a little bit of money for a project. Does anyone know off hand, with the use of a desktop dyno, preferable runner size and length for a 3100 engine with stock cam?
              • donk_316
                • Mar 2004
                • 427
                desktop dyno doesnt take into account runner length or diameter or for that matter plenum size to an extent
                1984 Indy Fiero 3.4L
                13.7 sec @ 98 mph
                *ALL THROTTLE AND NO BOTTLE*
                  Visionary
                  • Feb 2004
                  • 254
                  oh...
                  I look around
                    • 13533
                    What powerband are you wanting and what mods to the motor? Its mostly a trial and error deal but you can get get an idea of where to start at least. What sort of power output are you looking for?
                    • jp_grasshopper_007
                      Power Level:1,000,000
                      • Mar 2006
                      • 120
                      Dynomation does..... I've been told that it is pretty bad ass software
                      because I\'m not Canadian
                        Visionary
                        • Feb 2004
                        • 254
                        A starting point would be....
                        ....with the stock motor. So I would need stock numbers.
