In Depth: Crankshafts
    • 13522
    I have a 2.8 FWD crank and a 3.4 DOHC crank. I need some details explained since I dont know what is a counter weight vs anything else. It is interesting to see the DOHC is knife edged though compared to the 2.8 crank. Here are some pics that I have so far. What I need is a good explanation of the crank's job in the engine (i can probably think of something but I like as much input as possible) as well as explaining the differences between the cranks in our engines. Chris has 3.1 crank pics but I gotta hunt them down.
    Anyway, here are the pics I have.
    Thumbs posted, go here for full size pics.
    http://www.60degreev6.com/indepth/Crank/
    DOHC
    28
    DOHC
    28
    DOHC
    28
  • RebelGT
    • 642
    Odd that this is from a Navy publication, but here is a pretty good explanation of crankshaft terms, theory, oiling, etc...
    Its several pages long, so you need to click NEXT a few times. It looks like there is a bunch more info as well on other aspects of the engine.
    26+6=1
      • 13522
      Ill have to bookmark that and read it. Ill link to it though once the section is up. Time to hunt through Chris's cd of pics for the crank pics.
      • Anonymous
        can we use the 3.4 dohc crank in our 2.8 blocks with the rods and pistons
          • 13522
          As far as I know, it all swaps right in. If a 2.8 crank works in a DOHC, I think it works the other way around
          • sd_iconoclast
            • 126
            My machinist claims that the 3.1 crank is the same crank as the DOHC crank. This seems logical but I have begun to wonder if he just lostg my crank. DOes anyone know if they are they same? Are they made of the same material? Do they have the same part number?
              • 13522
              Different part number, same casting number. Not sure on metal used, or anything GM did to them after they were cast.
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                The knife edge is very aparent in thoes pictures. If you look on the DOHC Crank you can see the dual beveled edge on the leading side of the crank counter weight. This probabally helps reduce turbulance and would also relieve stresses in the metal.
                The 2.8L Crank does not have this. Now did 3.1L and 3.4L (pushrods) also have this knife edge design?
                  • 13522
                  both sides have this knife edge to them trailing and leading. The 3.x and 3x00 have this design as well.
                  • TheDirtyBen
                    • Mar 2004
                    • 130
                    i don't remember seeing the knife edge on my 94 3100 crank. btw, does anyone want my 3100 busted crank?
                    1994 Oldsmobile Achieva (2002 3100 SFI)
                    Homemade ram-effect CAI
                    K&N cylinder filter
                    Poorboy Lowering Kit
                    Front STB
                      • 9189
                      Give it to Ben so we can get some pictures!
                      • TheDirtyBen
                        • Mar 2004
                        • 130
                        i will, if i ever see him
                        K&N cylinder filter
                        Front STB
                        • XLR8ING
                          Too Stupid To Quit!
                          • 268
                          I've had a 3.1 MPFI crank side by side with a 3.4 DOHC crank, and from what I remember, they LOOK identical. Casting numbers were definately the same. I took pics, but I'll have to dig them up again.
                          The 3.4 crank was for a buddy. He converted his 2.8 Camaro motor to a 3.1 using the 3.4 crank and H562CP pistons.
                          I'll see if I can find the pics and post them here.
                          Franz
                          1990 Z24-NA 3.1L
                          14.72 @ 92.24 MPH
                          14.89 @ 94.92 MPH
                          The boost is coming....
                            • 9189
                            Well, I just pulled a crank out of an 01 3100 for a guy, so I'll take some pics to put up on the site, as well as get some numbers off of it.
                            • Wolf
                              • 181
                              you should weight the two cranks to see if theres a difference
                              3.4 pushrod crank is edged(and it says 3.1 on on of the counterweights if I remeber right)
                              when I take that gen 2 2.8 apart I'll see if its crank is edged or flat
                              1995 camaro 3.4 5-speed
