This Area
    • 13509
    This Area
    I set this up so that anything on the site that needs and update can be posted. Just post a link to the article, and express what needs to be changed. That is the fastest way to get something done on this site.
    I will also post up new discussions that I read on the forums here and elsewhere. A lot of discussions happen at the same time on different forums.
  • mlk
    • Nov 2003
    • 2
    New to site. Trying to post a query. Is it possible to reverse the intake on 2003 gm 3100 v6 for FWD facilitation. Removal and relocation of steering pump appears necessary. Has anyone tried this?
    Thanks,
    mlk
      • 13509
      you should ask in the pushrod general area.
      • sharkey
        • Jun 2004
        • 2061
        http://60degreev6.com/showthread.php?t=25036
        this is stating that the 92-94 quad 4 getrag uses a .72 5th gear. that is actualy incorrect, it has a .81 5th gear.
          • 13509
          Just create it in the wiki with the updated info.
            Maybe we should break it all down by tranny codes.. 3XTX, 4XTX etc...
              • 13509
              Sure, that would probably be best.
              • john_V63400
                Banned
                • Feb 2006
                • 409
                i liked the other site the last days, it was good, what happen
                  • 13509
                  Nothing, we just made the wiki the main site so that people can add information to it more easily. We will eventually do away with the current articles and only have the wiki for information.
                  Forum is still the same otherwise.
                  • Z3R0
                    • Nov 2006
                    • 90
                    There is a problem with outside forum links...it seems that when I click a link that leads to one of this sites threads, the wiki takes over and redirects to the [wiki] home page.
                    Originally posted by wozxx...{is 92 mph in a school zone illegal?}
                    I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
                      • 9185
                      Can you give an example so I can look into it?
                      • 34blazer
                        • Sep 2007
                        • 341
                        i didnt see anything pertaining to the crankshaft, i could be blind. maybe different casting p/n's thru the years and the best one to use in a particular build. i havent seen any aftermarket forgings out there so this could help for anyone producing over 400hp.
                        maybe some horsepower recipies for anyone interested like;
                        200-300hp recipies
                        300-400hp etc, etc.
                        just something to use as a guideline for novice engine builders like myself.
                        '86 Grand National
