The 60 degree family tree
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    #46
    Yea you can steal it if you want... I also have added credit for all the people in this discussion
      • 13531
      #47
      I can wait till its offically done. Thanks
      • Anonymous
        #48
        What about the 3.1 TBI that was in the minivans and Izuzu(sp)? Any info on them? Do they have iron or aluminum heads?
        • Anonymous
          #49
          iron.
          • geoffinbc
            • 5831
            #50
            Hey yea that messed... they were FWD blocks were they not? Did they have a FWD motor mount casting and the starter on the opposite side? Hmmmm WEIRD
            • Cliff8928
              • 532
              #51
              yes, there were plenty of FWDs with iron heads.... (all of them before 87)
              Cliff Scott
              89 BerettaGT
              89 Volvo740
              Cliff Scott
              89 BerettaGT
              04 AleroGX
              • geoffinbc
                • 5831
                #52
                Well no kidding... But what about the ones lasting to 1995 and using TBI?
                So I gotta add that when did the Lumina APV start and stop production?
                • geoffinbc
                  • 5831
                  #53
                  Ok so latest update includes the weird ass APV and also info on the Troopers. They got a 3.1L instead of a 2.8L in 1990 and they used a block with the starter on the drivers side but the same engine mounts as a raditional RWD motor... Is it possible the luminal also used a RWD style block... I also want to know about the Fiero did it use a RWD or FWD block? I know it had MPFI
                  • Cliff8928
                    • 532
                    #54
                    the starter on the traditional RWD motor is on the passenger side...
                    Cliff Scott
                    89 BerettaGT
                    89 Volvo740
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                    • geoffinbc
                      • 5831
                      #55
                      What I ment to say was did the lumina use a block with RWD mounting locations but the starter on the even number cylinder side (drivers side) like the Isuzu did. It may be this way since these were the only 2 vehicles to EVER use a 3.1L TBI engine.
                      • Anonymous
                        #56
                        Wow I feel so special to drive one
                        How strong are the transmissions on these things?
                        • geoffinbc
                          • 5831
                          #57
                          Probabally pretty good.
                          • Cliff8928
                            • 532
                            #58
                            the Lumina van is a 3.1 TBI, then it should have the 3T40 (aka TH125-C)
                            The lumina vans do however have the typical Gen 2 style timing cover...
                            Cliff Scott
                            89 BerettaGT
                            89 Volvo740
                            Cliff Scott
                            89 BerettaGT
                            04 AleroGX
                            • XLR8ING
                              Too Stupid To Quit!
                              • 268
                              #59
                              As a proud owner of a 1990 Pontiac Transport, I can shed a little light on this one I hope.
                              It's FWD with iron heads, distributor, TBI, T125 tranny, and from what I can tell is the exact same block as what a Lumina car would've got, just with the Camaro style 3.1 pistons I'm guessing. I know the passenger side motor mount is the style that mounts on the subframe if that explains anymore. I'll take a closer look at it later tonight, and get some pics of the mounts if anyone wants to see them.
                              Also, on the very early 2.8 FWDs, they had seperate V belt driven accessories, such as water pump, P/S and A/C. There was a Century or something like that at the wreckers a while ago that I was looking over rather closely. The intake on that car looked almost identical to a RWD camaro 2.8 MPFI. Something like a Fiero intake.
                              Franz
                              1990 Z24-NA 3.1L
                              14.72 @ 92.24 MPH
                              14.89 @ 94.92 MPH
                              The boost is coming....
                              • Cliff8928
                                • 532
                                #60
                                Yeah, and those older ones had the waterpump like on all the RWD engines (center of the timing cover), and the HUGE Delcotron alternator (CS144 size)
                                Cliff Scott
                                89 BerettaGT
                                89 Volvo740
                                Cliff Scott
                                89 BerettaGT
                                04 AleroGX
