What are our valves made of?
Valves
J-E-L-L-O!!!-60v6's 2nd Jon M.
They are sodium filled in the 60deg. V-6. This is good reading. http://www.angelfire.com/ca2/34Performance/dohc.html (I knew I read it somewhere) Doesn't mention stainless, but I would assume......At least that is what the author says.Originally posted by 93vinxlisted that way at my work, could be wrongeIf you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
I think you are being sarcastic! Are you trying to say that everything on the net is not true? That means I'll never have a bigger......Originally posted by dykz34Ok everyone, let's all chant together: "EVERYTHING WE READ ON THE INTERNET IS TRUE, EVERYTHING WE READ ON THE INTERNET IS TRUE..."
That was a little premature on my part.I will edit that post.
Isn't sodium that chemical that reacts violently with water? Ben and I cut a valve up and tossed it in some water to test this theory, and guess what. It sank just fine, it didn't blow up.Originally posted by Lyle's GTPYeah, the stock valves are not sodium filled. That JJ website was talking about the "Proposed" design. Because he also says the DOHC has a forged crank.....It doesn't
Lyle-60v6's 2nd Jon M.
