ok i was just playing around and trying to figure out what they are doing with the cams in the ly7. and its not adding up right at all! heres what they have listed in the gm spec sheet
-229 degrees BTDC
ATDC
111 degrees ATDC
132 degrees ATDC
ATDC
251 degrees ATDC
now how do i get from there to, duration at .050, intake centerline and lsa?
i did the math the old way, and its waaaayyy off. so i tried an online calculator, wayyyy off and entirely diff numbers this time.
whats the deal?
- Camshaft Timing @ 0.15 mm (0.0059 in) Lift
- Valve Opens - Exhaust
-229 degrees BTDC
- Valve Opens - Intake
ATDC
- Centerline - Exhaust
111 degrees ATDC
- Centerline - Intake
132 degrees ATDC
- Valve Closes - Exhaust
ATDC
- Valve Closes - Intake
251 degrees ATDC
whats the deal?
