Originally posted by torq455
View Post
Hi Jonathan,
Thanks for your interest in using us for a torque converter. I dont have a good suggestion for you off hand as I dont have much experience with your setup other than stock applications or stock and modified 3800 engines which will definately behave different. The problem with most stall rpm ratings is they are only for a stock engine in a given application and there is a world more to the true stall speed. Stock ratings are rarely ever accurate, nor are most aftermarket converters unless tested on a specific application. A 3200 rated converter could stall 2500 in one car and 3500 in the next. For custom built torque converters we use Precision Industries and they will build the converter to match the engine specs and desired stall speed, as well as to match the power adder being used if any. Not all converters are created equal and every combo and power adder will make the converter behave different. A 245mm converter for a fwd application is pretty universal across the board so there really isnt anything model specific. The Precision Industries torque converters use their own proprietary lockup clutch material that is fully compatible with the older on/off style tcc systems and also work fine with newer pwm tcc systems.
David Norris
Email: Dave@tripleedgeperformance.com
Website: www.tripleedgeperformance.com
David Norris
From: jack@converter.com [mailto:jack@converter.com]
Sent: Friday, October 14, 2011 10:39 AM
To: jpchmura@att.net
Subject: RE: Contact Us Form
The converter we make for your car is a 9.5" Vigilante with a CNC Billet Steel front cover, heavy duty lockup, all furnace brazed and comes with a 5 Year Warranty. The converter sells for $808.04 and the build time is around 5-7 working days.
800-649-7866
800-649-7866
I'll see what TCI Auto has to say. But right now I'm liking the responce and info RevMax has given me.
