96 Beretta Project
well, there's an easy solution to that as well, run a 200 shot!... lol. on a serious note though, is your "100 shot" corrected for 6 cylinders? a direct port 100 shot setup for a v8 is only going to net 75 on a V6.
Well I could and that was what I was originally going to do, but having 6 jets and only a 100 shot the orfice is very small and many told me that is a bad idea and could clog very easily. Granted fuel injectors probably have very similar small exit holes but it's hard to even find the jet I need because it's so small.
Originally posted by ericjon262 View PostI don't know nitrous systems well, but why can't you just run 43 psi like your injectors, with a tighter orifice in the nozzles?Originally posted by 3400-95-Modified View PostNow for Direct Port I need to drop my fuel pressure at the solenoid to the 8-12 range to allow for a larger fuel jet to prevent any possible clogs. If I kept the pressure at 55PSI then I would need a VERY small jet and the nitrous guys say that's just asking for a disaster.
I'm kind of curious why a tiny jet at higher pressure will be an issue with good filtering.
Also got my two cam choices from Ben yesterday...
Current cam specs adv dur 216/240 @ .050 .517/.568 lift 112LSA I believe it's a 113 ICL but not sure.
This is the best I can come up with without XFI lobes. XFi is 10 hp more in the mid range and 8 up top running less duration and more lift with a faster ramp up rate. The springs necessary are nitrided so that aspect would be better for longevity. The stiffer spring will probably stretch your double roller....ROFL not. Bearings might be an issue but I haven't heard of it. Lasted a year in a racing engine without an issue but thats not the same type application.
Xtreme Energy version Advertised by comp as 276/294 adv 224/242 @ .050 .536/.576 lift 113 ICL 115 LSA.
XFI version Advertised by comp as 268/286 adv 218/236 @ .050 .570/.579 lift 109 ICL 114 LSA.
I'm leaning towards the Xtreme Energy just because that will reuse the same springs I have and I haven't seen any long term ill effects form them. Heavier springs could cause premature cam bearing wear, lifter bleed down, or other unknown issues. And its only 10 more hp across the mid range and 8 on top... I can probably get that another way for less money and not as much fear of longevity issues, or just live without it since I'm sure it will already be better than what I have.
I re-sealed the firewall with the Napa sealant, did two thin coats this time so no areas cracked on me. I then sprayed over that coating with the Leak Seal stuff from rustolieum... Seems to work good. That also dried up nicely and didn't stay a tacky mess like some rubberized undercoatings do. I still need to clean up and spray the rest of the bay with the bed liner I got.
Here is the older fresh air vent cover in place as well...
Originally posted by 1988GTU View PostI cringe at the loop system you are entertaining. If you impede flow of the factory used return line in any way, it can make the feed psi be manic no matter how much checks and balances you put in its system.
And that regulator has a range of 35-85psi... It can't do indifferent pressures. The 2 port and 4 port options are just giving you more feeds for each item, One carb and two stages of nitrous for example. Some EFI regulators only have one inlet and one return meaning you would run the feed to your rail first then go to the regulator like stock... Ones that have the two port options give you the ability to setup a semi-returnless fuel setup and have the feed go to the regulator first and the return back to the tank and you just feed the second inlet to your rail. Then your rail will sit at the set pressure but it will use all the fuel delivered to it and not have any just passing through.
If aeromotive comes back with their solution being a bad idea then I will probably go for the NX tank solution. I'm just not a fan of trying to steal feed fuel for this setup... Which is the only reason why I was entertaining the return line since it would be excess fuel that's not being used that I'm taking. And in reality if the back pressure causes the first loop to read higher than originally set without it, then you can probably just adjust it down to compensate so when both are active they stay pretty stable. The secondary regulator would not see a VAC signal it would be static pressure so at least the return restriction would never change during operation and the worst it can do is spike my main pressure when enabled resulting in a rich condition.Last edited by 3400-95-Modified; 12-19-2014, 09:11 AM.
I am almost certain that regulating volts to the pump I linked should not pose any issues. Def contact there cs for clarification.
However, that other link I posted shows a dual feed regulator thats capable of maintaining pressures indifferent of each other, thats what I think im seeing.
I just don't see how that configuration is any less complex than the other two suggested... There is always a chance of failure and I feel that running a high volume racing pump off a feed supplied by my Walbro 255 in tank pump while limiting the voltage to that larger pump is just asking for something to go wrong.
The worst I can see happening with the dual loop system is the back pressure on the first loop creating inconsistent pressure or higher pressure when in use... The secondary fuel systems are marketed and sold as a system to ELIMINATE the chance of failure and ensure that each system is properly supplied with fuel and not have one trying to steal from another.
What your suggesting I've never seen attempted anywhere online so it's a shot in the dark on if it would even work, never mind how reliable it ends up being. I have my doubts because in all honesty there is nothing in that pump to prevent it from being overpowered by 55PSI of pressure from the first pump, it has no way to isolate the two separate systems.
Your chances of incurring a failure or multiple issues wouldn't be there tho. Less is better. It does come at a price in this case.
Well lets start with it's a $450 pump, which would still require a regulator on the other side of it... I mean I can get a dual regulator setup for $300 if the secondary loop idea works as Aeromotive suggested, OR I can buy one regulator for the EFI at $150 and a whole secondary fuel system kit with 1gal tank for $430 from nitrous express and not have to worry about affecting my EFI system at all.
It would over draw if you applied the level of voltage. Qhy not control it with voltage to drop the psi low enough to use a regulator appropriate?
yikes... supports 700-1000 HP... that would probably drain my line and kill the walbro pump since It can't keep up. Remember this whole system is working off of factory lines and pickup assembly.
I checked with Aeromotive to verify the dual bypass setup and having the low pressure one on the return side to see if that would affect anything. Once I hear back from them that will make my decision I guess. If that's a no go then stand alone system is really my best and only choice.Last edited by 3400-95-Modified; 12-18-2014, 09:58 AM.
This may be of consideration:
Or if you would "Y" off the feed line and use this: http://www.magnafuel.com/products/efi/pumps/MP-4301.htm
Set at the lowest out put (voltage/amps) then use a simple regulator to sustain the PSI you desire as a constant output.
