HATE IT.
Well, hate is probably too strong. It has a couple good qualities.
Despite not having a balance shaft like the 3800, it runs pretty smooth.
And as I noted in a post from a few years ago, it gets phenomenal fuel economy on the highway, which I will be needing soon.
I will be taking another trip to Kansas in a month or so. 2500 miles of driving uses plenty of fuel. So I need this car to be road ready and running well.
Neither of the wagons are suitable at this time, for very different reasons. One is mechanical, one is clerical.
The yellow sedan has been sitting in the garage since mid-2021 with a seized starter. In addition to the images you're seeing, I finally got around to that. It is not a particularly fun task, but I would do it again a dozen times if it meant I wouldn't have to do THIS JOB.
Everything you see above is about 2.5 hours of TEARDOWN to get to the thermostat on this engine. It's stuck open, which is fine in the summer but not so much in the winter. It means it didn't have anything approaching effective heat, it ran in whatever loop it is when cold and drank gas, the torque converter wouldn't lock because the transmission was cold. All of which translate to a miserable highway trip. As a contrast, when I've done a thermostat on the wagons, which have an L82 and an LX9, I'm in and out in like 45 minutes. I'm REALLY not looking forward to putting this all back together.
To answer a potential question, yeah, it may have been "easier" to pull the throttle body instead, but that risks breaking all kinds of water and vacuum hoses and the TB gasket that are quite difficult to come by, since this variant of the Buick engine was only used for a few years, and not very widely.
In related news, I robbed the radiator from the yellow car a few months back to install in the black wagon when it started leaking. So I need a replacement. Public service announcement: as cool as they are generally, I do not recommend buying a radiator through Rock Auto.
That kind of damage to the plastic portion is annoying, but understandable. THIS BULLSHIT ON THE OTHER HAND
I cannot fathom how it could have been CUT like this. I didn't take a picture, but the other side had a cut like this as well. To their credit, Rock Auto issued me a refund quite quickly and so far hasn't asked for it to be returned. I may attempt to have it repaired, though that would exceed the cost of replacing it. I know what that cost is, because I still needed something to put in the yellow car. So I yanked the core from George.
This is what ~10 years in Las Vegas looks like. I took it to a nearby radiator repair shop (those still exist!) and $150 later, this is what I have.
They cleaned it (necessary after running straight water for several months in an iron block engine) and repaired a small leak. Ready to run for another ten years!
