Thank you very much!
Sent from my HTC Hero S using Tapatalk 2
Wtb tce drtc!
Do you know how much you had to shave off the crank?
Pictures from Roberts install...
Turned crank
And you can see where I clearanced for the chain in the cover.
And No I have not had anything "fail" yet because I've caught it before that... A non GM timing set I curved the teeth on the crank gear and also had a very stretched chain causing dimples on my pistons from the exhaust valves. I've since been running an OEM GM timing set that was cryo treated and the last time I inspected it, it looked really good. I'd just like to have something that is a bit more "wear friendly" since really its not strength your gaining its the roller chain design that makes it better.
I'm not pushing big power yet, but I will be very soon, so I don't want to play games with a elcheapo timing set.
Also i think the front cover needs to be clearanced Jon should be able to tell us exactly he installed Robert's The crank needs turned down and the block needs alittle taken out of for the chain Marc has drawings somewhere on here i think
Also i can pay anytime and may get it cryo-treated anyway unless someone can give me a reason not to have it doneLast edited by unchained01; 10-22-2012, 01:23 PM.
For you guys pushing big power how many timing components have failed?
awesome, we up to 6 now. I'm unsure of trhe turnaround time though, like I said, I have not heard back from marc yet as to if he will even do it.
what kind of time frame are you looking at for payment given that this goes through.
with all the crap i put the engine through i'd be down for one.
strength is the advantage, the crankshaft has to be turned down a little bit to make the chain clear.Originally posted by ga2001532 View PostWhat is the advantage of the double roller. What other modification are need to.run them. I may be interested I just never understood the full details about these.
I will put money down for sure have been trying to find one this group by need to go thru!!
i will post on GAOC ,aleromod and GAGT. I dont want to get too far ahead thou. Unless we have a reply i think its futile right now
trying to arrange a GP, not sure if marc will go for it yet, but so far we have 3 people. Please, let me know if you are SERIOUS.Last edited by ericjon262; 10-15-2012, 12:48 PM.
