There is a throttle follower steps constant that will change how fast the RPMs drop between shifts for manual transmission. Tables Maximum vs rpm and vs mph will control the drivability in gear but at $0DE3 in the stock A1 code there is a manual trans throttle follower.
0DE3 10 16 KISMANOF 16 STEPS THROTTLE FOLLOWER OFFSET FOR A MANUAL VEHICLE, IF THE
VEHICLE IS MOVING.
VEHICLE IS MOVING.
), couldn't get the TPS to go to an idle position, stuff like that. everything else is working though, managed to calibrate a few instrument clusters (bad tachs and speedos) in the process, so the bench has already paid for itself and then some.
