Originally posted by flimbob
View Post
3500 (LX9) swap into a Fiero
Avoiding any changes that move backwards in technology is a good thing whenever possible. The newer the parts the better. The adjustable regulator is also an attribute and having the ability to attach an inexpensive pressure gauge to it is another plus if ever you have a starting problem and have to diagnose. It's not a complicated accomodation at all, you're basically attaching lines to the regulator instead of the rail and running one line instead of two to the engine.
If you got it figured out and the parts aren't that expensive go for it. Used 24# from a DOHC or something do show up every now and then for sale though.sigpic
The problem with DOHC injectors is that the spray pattern is specific for the DOHC valve design with a wider spray pattern instead of conical which is used on single intake valve ports. They will work with no problem however the spray pattern will result in more fuel being sprayed towards the walls of the intake runner. I forgot the degree of the angle but the DOHC injector was designed so that fuel would be sprayed evenly at each intake valve in an oval shape to hit both valves rather than the narrower conical pattern aimed at a single valve.Originally posted by IsaacHayes View PostIf you got it figured out and the parts aren't that expensive go for it. Used 24# from a DOHC or something do show up every now and then for sale though.
If you run your 19's @ 55 PSI (22.5 lb/hr) they will work if the engine is stock.
the dipsticks are all the same for the gen3 engines, if you go to the yard grab a few because it's common for them to break.
FWIW, we ran 3.4 DOHC injectors in a 3400 with a cam and ported heads with no problems. Getting ready to put them in a stock 3500 in a few weeks.
True they work Superdave, I believe in this situation he's better off working with what he has instead of opting for what must be at least 10 yr old technology and parts for that matter if the last production year of the 3.4 DOHC is 1996. It's tough enough discouraging Fiero swappers from switching out aluminum heads for cast iron heads on roller cam blocks.Originally posted by Superdave View PostIf you run your 19's @ 55 PSI (22.5 lb/hr) they will work if the engine is stock.
lol, but there is quite a difference there... iron heads are the devil, old but good injectors will still perform well as long as they are clean.Originally posted by Joseph Upson View PostTrue they work Superdave, I believe in this situation he's better off working with what he has instead of opting for what must be at least 10 yr old technology and parts for that matter if the last production year of the 3.4 DOHC is 1996. It's tough enough discouraging Fiero swappers from switching out aluminum heads for cast iron heads on roller cam blocks.
My Sy/Ty injectors still work fine and they are 19 yrs old.
That's good input on the 19's @ 55 PSI. I thought I read somewhere ( here on the forum ) that the stock 3400 FPR is 55 PSI.Originally posted by Superdave View PostIf you run your 19's @ 55 PSI (22.5 lb/hr) they will work if the engine is stock.
FWIW, we ran 3.4 DOHC injectors in a 3400 with a cam and ported heads with no problems. Getting ready to put them in a stock 3500 in a few weeks.Last edited by flimbob; 03-01-2010, 12:19 PM.
