Sweet!
is that a work light on your inner fender?
 The other great surprise is that without cutting the driveshaft shorter, it was the right length, though it could be about 10 to 15mm longer without issue. I do have about 60mm of yoke engagement as it is, which is over half of the overall length of the yoke.
 Right now I am down to only 4 couplers in the entire system.
 Right now I am down to only 4 couplers in the entire system.  One at the turbo compressor, one at the TB and one at each end of the IC. It took some real effort to get this to work, but I like the end result, and once the vent boots go back it it will look even better.
