4T60-e shift Kit?
  • #76
    Just a note: Thinking outside the box as I sometimes do, I used some engine valve springs I had laying around when I did this. Worked very well. The washers I got from Home Depot in the bolt section. Just bring your parts with you and see what will drop in the hole.
    '97 Chevy Lumina, '99 LA1, ported heads, manifolds, 2 1/2" exhaust, k&n filter, 180* stat, A/C delete, Ram air, 3600 FAFB converter, 4T60E shift kit, DHP Power Tuner, AEM UEGO, MegaSquirt II/Extra
    1/8 mile 9.72@75 mph, 2.0 60 foot:owneddance:
    [url=http://videos.streetfire.net/video/fbf6af9e-55a9-4604-b3e9-9a290119f6c9.htm][img]http://thumbs.streetfire.net/fbf6af9e-55a9-4604-b3e9-9a290119f6c9.jpg[/img][/url][url=http://videos.streetfire.net/video/fbf6af9e-55a9-4604-b3e9-9a290119f6c9.htm] [/url]
    • #77
      DRY transmission, Freshly built, with no converter weighs in at 161lbs with side motor mount on.
      Converter is 20lbs dry...
      So I would say add about 10-12 quarts of fluid to that, and thats your total trans weight. The converter can hold like 3-4 quarts I THINK... and when that comes off the fluid doesn't drain out of that easily so even dropping the pan your only getting out about 5-6 quarts of oil... so yeah. It's heavy.
      Dry with converter the trans weighs just about what I do... and it's shaped like a friken beach ball with a 80lb leg...
      [IMG]http://i257.photobucket.com/albums/hh201/3400modified/DragTimeSig.jpg[/IMG]
      [url=http://vid257.photobucket.com/albums/hh201/3400modified/Pinky%20Parts/20150506_200838_zpsjzkh1x14.mp4]Got Lope?[/url]
      • #78
        Damn!! Weighs more than a TH350/TH400!! (but does have the diff inside too)
        [/SIZE]
        • #79
          the diff isnt THAT heavy... Maybe 15lbs if that. Also remember a TH350/TH400 is a straight shot, this one has gears and a chain, and probably more case material too.
          • #80
            what brand rebuild kit did you get?
            • #81
              Trans Star
              • #82
                It may be a few weeks till I get around to this shift kit....
                booo..
                weather sucks and I'm freaking busy.
                [IMG]http://img.photobucket.com/albums/v639/AWeb/54512.png[/IMG]
                [b]The new Z06 exposes European sports cars for what they really are....overprice, underperforming snobs.[/b]
                • #83
                  will th-400 adjustable modulators work on the 4t60e?
                  • #84
                    Yup, the TH350/TH400/Powerglide one I have on mine. It fit's other trans too but yeah..
                    [/SIZE]
                    • #85
                      sweet.. thanks
                      what about the plug in "shift kit".. does it even do anything?
                      • #86
                        I don't think so, it was discussed once and I think we figured it wouldn't work for the 46t0-e, since it's vacuum controlled line pressure.
                        I have the adjustable pioneer one from o-reillys, with it turned in 4 turns from where it's at out of the box (max it recommends) and shifts are nice and clean, not too harsh at part throttle, and I have a poly insert in my upper mount even.
                        [/SIZE]
                        • #87
                          3400Modified....Where On The Diff Is The Tag To Tell Me What Accum I Have? I Can Only Get Under Half The Car Because It Is So Low. I Don't Want To Start It Just To Move It (I Have To Drive It On Blocks To Set A Jack Under It). I Can't See Any Tag Or Markings Anywhere. And My RPO Code Doesn't Say Anything.
                          • #88
                            Passenger side, between the firewall and trans, there should be a metal tag on the trans. It might be aimed up towards the sky a bit.
                            [/SIZE]
                            • #89
                              crap...guess i'll have to pull it up...although, I think I can see teh tag from above....maybe I'll try a mirror down there....
                              • #90
                                where did you get the polly mounts?
