ok finished the 3400 swap into my beretta a while ago and still havent been able to drive it cuz theres no oil pressure! when i first had it running there was pressure and everything ran fine then it just stopped having pressure dropped to 0 and i noticed the oil pump drive gear was popped out of the block! so i then realized my motor didnt come with the little bracket that holds it down so i made one and it turned out fine but still have no oil pressure and the top ends ticking like a time bomb!
what to do?! do i just tear the pan out and have a look? does it take a while for the pressure to pick back up? cuz i only let the car run for 30 seconds this time and it was still at 0 and ticking loud! i'd hate to tear the pan off and the rest of the suspension if its just cuz i didnt let it run long enough. what would you do? run it longer to see if it comes on or tear everything apart?
