problem with 2 stroke oil: it might screw with the cat.
the reason i asked if the engine was still out was so that if it was, just fill a little oil in it, and make it a george foreman grill: just rotate it... a lot and that would get up the cylinder walls.
EDIT: fogging oil might help...
i heard some guys use it to lube cylinder walls on engines not assembled to keep them from rusting out so i was wondering if it would be a good idea? main reason is the pistons sit like this \ / so hows the oil gonna get to the very top of the rings/cylinder? im thinking wd40 can be aimed directly where i want it through the spark plug hole and i wont have to use no where near as much like it would if i were to use oil.
