Originally posted by 60dgrzbelow0
View Post
...and using one of THESE as the means to keep the EFI Cleaning Fluid as clean and pure as possible when re-cycling the stuff again and again...
...but knowing that this gravity-style fuel filter might not be able hold up under the stress of having as much as 45 PSI applied to it.. (might just explode and spray the stuff all over the place...) Nonetheless... this might be a healthy alternative to adding both simplicity and portability to cleaning individual EFIS...and the COOL part is... that the hand pump is capable of generating up to 45 PSI before the automatic relief valve releases any excess pressure... so you would not require a Fuel Pressure Gauge to monitor the fuel pressure... the only other things you would need is some Acrylic Hosing attached to the base (outflow side) of the EFI to capture the "spent" EFI Cleaner into a fancy Clear Plastic Gallon Water Jug like I use on "The FrankInjector Machine" and a single OTC unit to power the EFI electronically...and Voila! You could at least do the pressure cleaning phase of this job...with minimal expense and without any complicated hardware... Hell... All you would need to power the OTC Unit is to clamp the 12Volt Power lines (red & black) to any car battery...and you could clean your fuel injectors...right out in the wild beyond if you had to! Props to the original poster (jmgtp) that "Simple is Often Better!"...
P.S. I wonder if the Fuel Filter could be strengthened with a good wrap of Duct Tape after the fuel lines are clamped on?
