Well after providing Robert I with some useless advice back on the ALDL thread, I was debating whether or not to post this. But here's a link of a commercial chip meant for operating injectors. They give a sample diagram with transistor specs and so forth, that's not the problem.
What this shows is you end up getting into a bit of electronics fabrication to accomplish what everyone hoped would be just a simple fan-out from one injector to 6. You have to find a supplier, build up a circuit board and so on -- not a show stopper but it's cutting down on the potential number of folks willing to do so.
Now I say that the controller approach is needed since you're trying to operate the injectors as they would go in a real engine. A current pulse much higher than the device can sustain is required to get them opening quickly, and then you drop to a steady hold-open current. If you string all of the devices in parallel the feedback to the controller isn't going to be right even if you have a transistor (or bank of them) able to drive them. So it looks like there isn't a short cut to parallel 6 of them. You might be able to get clever and run two or 3 per driver chip and cut down on the parts count though.
Food for thought.
Food for thought.
I have a line on a job at Keystone RV. I'm hoping things work out because from the looks of it that place looked like a good place to work and has always been known as a place that makes good money. Sad thing is, if that place doesn't work out (because it's pretty much been my only line on a job lately) I'm going to end up losing my house, which is going to screw the people we are renting from because their plumbing business isn't doing so hot at the moment either. In reality, this area still really really sucks as far as jobs go. Thanks for the link to that site, but sadly as far as "real" experience goes (the way the real world sees it) I have none. I've got my A+ and Net+ in computers, but that amounts to about as much as having a pair of wire strippers and calling yourself an electrician.
