3100 Performance
    replied
    What does delta charge for a new cam and regrind. I don't sell used hollow tube bullshit. You talk about reliability and then say "junk yard cam with regrind'. ROFL!
    This thread isn't about your goals for glory. Its about 220-250 chp, which doesn't require new rods or pistons. Stock rods better take 300 with ARP rod bolts. The 3800 uses shitty cast rods (ROFL) and we have forged steel rods stock.
    Show me a broken crank and then we can talk about your destroked wonder crank from eagle. Or how about you start a thread about what YOU want to build.
    Im not sure what you can get out of a 3100 without porting the heads honestly. Headers, larger throttle body, 3400 heads, ported 3400 manifolds...might get you there.
  • fivepointhustla
    replied
    Originally posted by Sidewinder View Post
    All I need right now are mods that'll get me close/bang on to 220 - 250 HP. If I don't need heads or anything else except what was listed earlier then I don't see a reason to add them to my list (for those that are posting that :P). Unless I actually do need 'em?
    Yes I mean CHP, it makes more sense to me right now
    Oh and again, thanks for all the help guys!
    BEST bang for the buck is going to be nitrous. Cheap, reliable and easy (IF done properly isn't hard)...Fat chance of getting there all motor.
  • fivepointhustla
    replied
    [oijuoji
  • Sidewinder
    replied
    replied
    Im pretty sure he is talking CHP and the MMS numbers are at the wheels.
  • IsaacHayes
    replied
    Best bang for the buck would be new large port intake manifold. Since your 3100 is a 96 you should have roller rockers. If you do, then swapping on a large port lower and upper is a no brainer. If you don't then you'll have to grind the LIM to clearance like I did, or swap on new heads (3400 or 2000+ 3100 heads) which gain you a little better performance too.
    Now for a direct bolt on LIM to your coolant pipe, you'll need a 96-97 (maybe 9 mini van. It's threaded for your coolant pipe. or get a newer one and tap it.
    The 2000+ upper will bolt on and you can use the new style EGR with your existing wiring, but you might need the metal tube that goes to the exhaust. A 3500 upper requires a little more modification, and porting, but is even better. It has the same style EGR as 2000+. Click my avatar, then select all threads started by user, and look for 3500 swap check list I think is the title. I've got a lot of stuff in that thread detailed out for the 3500 upper.
    For a direct bolt on upper, a 3400 from the same year mini-vans would work too, and your EGR goes right up to it.
    So intakes or heads and intakes would be good if you dont want to pull the motor. And yes good designed headers would be cool.
    Question: When you guys are saying crank horsepower, you guys aren't rating it net are you? Cause net a whole 3400 is only 185....
    replied
    eagle makes a 2.8 crank that is cast steel. I sell regrinds for 300 using a new solid core cam. V8 rods just weigh more and aren't needed for most apps, custom pistons if you want higher compression or forged but you need a lot of boost to make that necessary.
  • fivepointhustla
    replied
    Sorry I should have been specific. V8 rods and bearings, stock or eagle crank, custom pistons. I forgot delta ran out of blanks, but you can send a junk yard cam to them for cheaper than $350.
    replied
    forged shortblock? Cheaper custom cam? Where?
  • fivepointhustla
    replied
    Just for the heads, IM, cam and exhaust w/o any mufflers your looking at a little over 2k. Now from the looks of that intake you could do the same port job, get a cheaper custom cam, forged shortblock and a juice kit for a little more than just 2-2.5k!
    replied
    Well, with boost you can do it cheaper but to build up an engine to make the most from NA or boost is going to require money.
  • Sidewinder
    replied
    I was originally thinking about doing similar mods, but after talking to people (including those on this forum), I think I have changed my mind.
  • fivepointhustla
    replied
    Copy pasted from the website:
    Blair Henze's '98 Lumina LS
    Blair's Lumina puts down 183.7HP & 178.7TQ at the wheels. Dyno Sheet
    Stage 2 3100 - Proof that good things do come in small packages
    Milzy Motorsports 3100 Cold Air Intake
    Milzy Motorsports 2.5" Dual Exhaust w/ Magnaflow Round Muffler, no cat
    Milzy Motorsports Stage 2 Camshaft
    Milzy Motorsports Ported & Polished 3100 Upper and Lower Intake Manifolds (2000+ style)
    Milzy Motorsports Stage 2 3100 Heads (milled .020")
    Fast Forward Under-Drive Crank Pulley
    Milzy Motorsports Stage 2 PCM
    Intense Poly Motor Mounts
    ZZP Billet Dogbones
    Autolite 104's
    180* T-Stat
    EGR Delete
    3400 Throttle Body
    BMR Front and Rear Lateral Arms
    BMR Trailing Arms
    GM Front Strut Tower Bar
    The stage 2 heads alone cost "$1,199.99" (copy pasted), let alone everything else done to get to that point.
    PLEASE tell me you are not trying to mimic this motor...For the money invested you could have a 300-400hp 3100 for cheaper.
  • El_Diablo
    replied
    remember the AMG incedent a few years back? poor poor amg owners... oh wait, their amg owners, they aren't poor at all so f' them
    best bet is getting a new, low mileage 3400 out of something like an equinox and then swapping on your parts, not really that hard
  • Tdunk
    replied
    Well reguradless of how many miles she may have trust me she's old and could go out at any time. Then again ive seen new cars go out right after someones bought them.
