Originally posted by Shaun41178
View Post
You're one to talk about wrong... you're wrong all the time. I'm making more than 230whp. I WAS (key word was) making 235whp almost three years ago untuned with maxed out stock injectors and a stock cam, and running the same times with a trans with burned out clutch plates... and guess what, I was still faster than you are now. I guess they say BS walks... so put up or shut up!
Everything with my fuel and engine management has changed since then and once I'm done street tuning it (hard to do in winter in detroit when the cars in storage) I'll be going to the dyno again for new numbers. Then I'll be going to the track again for new slips, and I'll be further blowing away anything that you can put down, all with my crappy magnacharger setup thats still faster than anything you have.
Anyway, back on topic. To give a definitive answer once and for all, NO YOU DO NOT NEED LS6 SPRINGS WHEN RUNNING BOOST!!!!!!! Multiple the psi you will be running by the area of the back of the intake valve. That will tell how much counter force you are actually getting against the spring pressure and you'll see it's not all that much compared to the forces you get with a bigger cam and more rpm. That is the real factor in determining if you need stiffer springs. If you are running boost AND raising the rev limiter, then yes stiffer springs might be a good idea but you can use 3500 springs which are stiffer than 3400 springs and don't require you to change the spring seat and valve seal like the LS6 springs do (which is extra cost). The LS6 springs would be overkill. If you are getting or plan on getting a bigger cam too, then yes you'll want LS6 springs. Once again shaun=owned hard.
