OK, is the bracket for the throttle cables (the one that bolts on top of the 3500 adapter and has that little piece that goes over the PCV tube on the intake to keep it in place) supposed to fit on without cutting? Becuase well, mine won't. I can get the top 2 bolts lined up, cut then the "leg" on the bottom/left of the throttle body isn't anywhere near it's screw hole. If I put the "leg" up first, then there is no way for the top to bolt on unless I really bent the bracket somehow.
Sounds confusing yes but I don't get how this is supposed to work. I don't even have the bolts for the throttle body... so I can't decide if the bracket's "leg" is even supposed to screw in.
