  • Originally posted by gectek View Post
    i have an update!
    Worst Post Ever!!!
    [SIGPIC][/SIGPIC]
    • suspense is great....ill wait a little bit longer...heh
      • Does it have anything to do with Scorpion taking over some of Crane's parts, now that they are no more??
        [SIGPIC][/SIGPIC]
        • NO, but since you said that, I also just now found out that Scorpion will be making valves, springs, lifters, and a few other valvetrain products as well as rockers. They just started to expand. Ill give more info when i get a few more emails from scorp.
            i have an update!
            [U]Your local OBDII moderator[/U]
            2000 Grand Am GT w/ WOT parts
            • solid rollers and a way to adapt their rockers to adjustable. get r done.
              • Looks like 2 months and these things will be nearly ready to go into all our vehicles. They are waiting on final design and material now.
                • nice sounds good. 2 months is cool and at least these are an easy swap
                  [SIGPIC][/SIGPIC] [IMG]http://i60.photobucket.com/albums/h5/95blackz26/sigpic2.jpg[/IMG]
                  [SIZE=1][B]99 Grand Am GT[/B][/SIZE]
                  [SIZE=1]3400/3500 -Solid trans mount--TCE 65mm T-body---85mm LS2 maf---1 1/4' TCE intake spacers with 3400 upper--SLP Catback with flowmaster 80--TOG headers
                  [URL="http://www.wot-tech.com/shop/cams/rollerregrinds/stock3400sims/3400%20with%20Ported%203500%20Top%20End/1357.pdf"]1357[/URL] cam 227 233 .050 dur[/SIZE][SIZE=1] 515 515 lift 112 lsa
                  15.232@88.85mph on stock 3400---New time to come[/SIZE]
                  [URL="http://www.motortopia.com/garage/cars/95blackz26"]
                  [/URL]
                  • I can wait two months... Now I have time to save up for it
                    [IMG]http://i257.photobucket.com/albums/hh201/3400modified/DragTimeSig.jpg[/IMG]
                    [url=http://vid257.photobucket.com/albums/hh201/3400modified/Pinky%20Parts/20150506_200838_zpsjzkh1x14.mp4]Got Lope?[/url]
                    • Originally posted by SappySE107 View Post
                      I still think 1.8 intake 1.7 exhaust would be ideal for stock cams. Even a straight 1.8 set but I don't think the exhaust needs 1.8, especially on a 3500.
                      Thanx Ben!
                      Put me down for a 1.8/1.7 set the minute they are available.
                      Much appreciated!
                      • Ben if you can do a split set for Eric, I'll take the other half of his order to do the same thing... I think 1.8/1.7 would work for me or is 1.7 all around a better setup...
                        1.7 ratio lifts, 549/603
                        1.7E 1.8I lifts 581/603
                        1.8 ratio lifts 581/639
                        You tell me what would be the best... I'm running the Comp springs from your store and stock valve seals just a FYI.
                          Good to hear. Keep it coming John.
                          • Heck yeah! Ben, you still think on a 3400 with the 3500 UIM, 65mm TB, better exhaust, and headers with a tune, it's still better to go with the 1.8/1.7?
                            Andy
                            [SIGPIC][/SIGPIC]
                            fastest 1/8: 10.19@ 67.17
                            fastest 1/4: 16.16@ 82.70
                            62mm TB, 1.6 roller tip rockers, Ostrich 2.0, UD pulley, TB heater bypass, K&N, 180* stat, No cat, 99Grand AM dual cooling fans. 4T65E swap FDR 3.69, EP LSD, F.A.S.T. transmission controller, TransGo shift kit.:cheers:
                            • Just want to get in on this,I will need 1:9 ratio I suppose as with my cam I lost lift and gained a little duration,These rockers should surely add some power eh?
                              [IMG]http://img.photobucket.com/albums/v320/budman52/Clipboard02copy.jpg[/IMG]
                              [IMG]http://img.photobucket.com/albums/v320/budman52/stuff.jpg[/IMG]
                              • if theres another person that wants to do the split 1.7 1.8 set then im good otherwise ill go 1.7
                                [/URL]
