NO, but since you said that, I also just now found out that Scorpion will be making valves, springs, lifters, and a few other valvetrain products as well as rockers. They just started to expand. Ill give more info when i get a few more emails from scorp.
I still think 1.8 intake 1.7 exhaust would be ideal for stock cams. Even a straight 1.8 set but I don't think the exhaust needs 1.8, especially on a 3500.
Thanx Ben!
Put me down for a 1.8/1.7 set the minute they are available.
Ben if you can do a split set for Eric, I'll take the other half of his order to do the same thing... I think 1.8/1.7 would work for me or is 1.7 all around a better setup...
1.7 ratio lifts, 549/603
1.7E 1.8I lifts 581/603
1.8 ratio lifts 581/639
You tell me what would be the best... I'm running the Comp springs from your store and stock valve seals just a FYI.
Heck yeah! Ben, you still think on a 3400 with the 3500 UIM, 65mm TB, better exhaust, and headers with a tune, it's still better to go with the 1.8/1.7?
Just want to get in on this,I will need 1:9 ratio I suppose as with my cam I lost lift and gained a little duration,These rockers should surely add some power eh?
