will it survive 28 psi?
  • you don't wanna break it but you're "beating the piss out of it? lol what the hell did you do so that wouldn't blow at 8k rpm? damn thing sounds sweet up there too! wowzers!! nice work.
    Andy
    [SIGPIC][/SIGPIC]
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    62mm TB, 1.6 roller tip rockers, Ostrich 2.0, UD pulley, TB heater bypass, K&N, 180* stat, No cat, 99Grand AM dual cooling fans. 4T65E swap FDR 3.69, EP LSD, F.A.S.T. transmission controller, TransGo shift kit.:cheers:
    • thnx man
      i cant exactly explain that one yet, but after the dyno when i rip the motor down to transfer everything to the new block i will post detailed pics and specs.
      8k was an accident, that actually the highest ive reved it yet,7,700 was the max before this.
      but it didnt miss a beat or float the valves, but it does have a real high spring rate valve spring in it. i have to get the part number off the box and dbl check it to verify but i belive the springs are 125# seat and 345+ open
      #1 1989 RS - THE L98 AND LT1/LS1 KILLER
      1LE SUSPENSION AND BRAKE SWAP,3.1L V6 8.5-1 CR, LIGHTENED CRANK,KB COATED PISTONS, CUSTOM 268/272 DUR CAM, CNC'ED HEADS, PORTED INTAKE,CUSTOM TURBO KIT W/ 67MM TURBO(AKA TO4R/Z) [B]28 PSI[/B], TCI STREETFIGHTER 700R4 W/ TCI 4,500 STALL,ALL RUN BY A MEGASQUIRT ENGINE MANAGEMENT SYSTEM
      #2 95 granprix 3100 all stock for now
      ported heads and cam comming soon, megasquirt ems and turbo down the road
      • Originally posted by project89 View Post
        me either when i rip the motor down to change blocks u will see just what im talking about.
        u guys really have no clue
        I think it's you that's in the dark
        I'm not going to say anything else other than just know that there is always someone out there who has done more research than you, laughing at your mistakes. I always have that in the back of my mind.
        I made the claim that I have the fastest all motor V6 cavalier, and i backed that up with timeslips, track/dyno videos, dyno sheets and witnesses. Just waiting on yours..
        • Originally posted by Superdave View Post
          so have i there is no faster 60* powered f-body as of yet, the closest one is a full half second slower then when i had the old turbo.the proof is already posted on these boards.
          u guys dont even know what size motor im running but u will find out when it gets torn down
          • I just called the dyno place with no answer. i assume you are already there or will be soon. Ill try again in a couple min. Probably can't hear shit with vehicles on the dyno.
            • ben assuming u called right before ur post time my car was on the dyno. i sent u a pm and will leave it upto u if u want to tell everyone about the issues we had.
              best pull was 268rwhp and 367.6 ftlbs @10 psi but that pull was aborted at 4,200 rpms
              as i told ben i setup another apointment for this wensday to fix a few issues that we had with the car.im not even gonna bother saying what they were.when ben hears it from jay the shop owner i will let him post up
              vids and pics of graphs should be up soon
              • oh no..... how bad has the shit hit the fan, ben?
                • Originally posted by robertisaar View Post
                  i didnt break nothing, though the dyno poped something during on of my pulls,
                  suring my second pull we heard this loud band and all the sudden this loud hissing sound,soon as the bang wa sheard the pull was aborted, it seems liek an ait hose or something ruptered under the dyno but it didnt affect it in anyway.
                  my issues were electronic issues and i prolly could have fixed it there but jay was being really cool and my car was on the dyno for a while and other ppl were waiting, so i said hell with it ill just come back so i didnt hold everyone else up
                  ive made ben aware of the exact issues we had but i will let him hear it from jay and let him post them if he so likes or ill just post the new dyno numbers when i go back with the car sorted out
                  • oh, i expected a piston/rod going through the oil pan/block or something to that effect.... sounded like the numbers were coming along nicely until the abort, yes?
                      when that hose or whatever happened on the dyno came apart we thought i kicked the rods out of the motor it was friggen loud, when i get the vids up im sure u will see everyone jump and hear it
                      well ok im gonna have to post up what the issues was for u to understand
                      my peak hp and tq should happen up in the 5,500-6,200 range with the cam im using
                      before the dyno i had reverted ignition control back to my stock ecm,not relizing that without the factory maf on the inlet of the turbo that the ecm would not advance ignition timing.so what we did was unhook the maf this set the ecm into limp home mode which pulls out all the ignition timing.
                      we also verified this with a timming light on the dyno, max ignition timming was *8 btdc, no timming = no power and no ability to rev the motor up
                      peak numbers occured right around 4k so they should have been much higher
                      im not disapointed shit happens,i know what the issue is and its simple to fix so when i go back on wensday ill have some accurate numbers to post
                      to make a best quess on what it would have done id say around 350rwhp if the ignition was advancing @ 10#'s of boost
                      even witht he low hp number today im not really disapointed 370 ftlbs with how the car was dynoed is no small feat in its own
                      • so at 10 lbs you figured you were making 350? so i guess you passed your 9psi/300HP guess earlier...
                          we figure it should make that at 10 psi but we will see
                          when we figured the 300rwhp was with the old turbo at 9 psi with a race wight of just under 3450 pounds,we did calcs to come up with that number and they are generally really close but not exact
                          we did the calcs with et vs wirght and also checked it with mph vs car wieght one comes up as 311rwhp the other comes up as 307rwhp
                          • vid
                            one the second pull after i let off u can her an air hose rupture under the dyno.we all thought for sure that i kicked the rods out of the motor,i shut the motor off soon as i heard it but after about 30 seconds we relized it wasnt the car making the noise
                            • damn almost 400 torque on 10 psi thats crazy ha ha its like taking the stock numbers an doubling them damn imagine what 28 psi will do
                              • Originally posted by nixon5 View Post
                                lmao nex time i need to pull a tree stump i wont need to go borrow my friends truck lmao ill just hook a chain up to the camaro
                                btw jay told me to figure 25% loss for the 700r4 and 4,500 stall converter
                                so figure these are the flywheel numbers
                                335 crank & 462 ftlbs
                                not to shabby under the circumstances
