Originally posted by 3400beretta
View Post
Need Help choosing a Walbro 255 Pump
Unfortunately, many times that causes the pump to cut out and draw air at 1/4 tank and below.As of April 2
Engine: 2006 SV6 3500 LX9
Trans: 2002 Getrag F23 5speed
Injectors: #36 GTPs
TB: 65mm TCE
Maf: 1999 3400 Montana.
Beverages: Ice Cold CANADIAN.
Seems (reading over my info again) the Berettas are a little different.
The J body and W body Venturi systems need to be modified.
They have tried a T fitting but was not able to keep the bucket full.As of April 2
Injectors: #36 GTPs
TB: 65mm TCE
You mean like thisOriginally posted by 3400beretta View PostIts a T fitting that goes on the output of the pump, there is no modding, thats the point. If you don't use the venturi system, then you have to hack your bucket apart, and then you CANNOT run your tank below 1/4 or the pump will starve for fuel.
LOL
Yeah I didn't like that whole venturi system, But I have yet to notice any issues with fuel pressure when run below a 1/4 tank
I buy my pumps from APE USA. Never had a problem with one yet, and the one I bought back in 05 is still in my red car running strong. I used the FPG003 kit.
I got mine from APE where you linked... The GSS307 or the High Pressure version are what you want... (the HP version has a Larger inlet which is kinda big but i got it to work with my OE sending unit pretty easy) if your running a FMU i would recommend the HP version (holds volume better under high pressure apps (FMU) )
The W-bodie's don't have a "Bucket" on the fuel sending unit.
SLast edited by RedZMonte; 03-10-2010, 04:19 PM.Shane "RedZMonte"
1992 Lumina Z34-VIRGIN (RIP)
1992 L67 Lumina Z34 (SOLD)
1990 Turbo Grand Prix (SOLD)
great, thanks for the help. I had ordered the gss307. The shop didn't get the $10 stock pump in yet so they will wait for the gss307. The tech said he could get it to fit even if it needed a little modifying. He said he done stuff like that before so no worries.Originally posted by RedZMonte View PostI got mine from APE where you linked... The GSS307 or the High Pressure version are what you want... (the HP version has a Larger inlet which is kinda big but i got it to work with my OE sending unit pretty easy) if your running a FMU i would recommend the HP version (holds volume better under high pressure apps (FMU) )
S
No FMU, the fuel supply is increased through the PCM tuning with 36# inj.
Now, I need to research MAF tuning a little more while I wait. I'm soo close to completion.
So far, one step at a time. I'm going to take a week or two break once the engine is tuned and the car is streetable. Then it's time to do some body work. Only a few dings and no real dents. Shes gonna get a good power sanding, two color priming to find surface defects then a nice full gloss paint job, finish with a waxing. Call me crazy but I like waxing my car. It is gratifying.
Again, thanks for all your help guys.
This was a great install guide for the walbro in a first gen W body, but for me the pics are down. YMMV
The non hp 255 pump is nearly identical to the factory unit and is literally plug and play. Getting the tank in and out is the bitch. The pump is cake.
Yeah, that is why the shop is doing it. For $100, that isn't bad at all.Originally posted by ghrarhg View PostGetting the tank in and out is the bitch. The pump is cake.
I can jack up the front end nice and high to get under due to the way the frame is. But the rear I can only get so high and it is too cramped to drop the tank. If the straps were clean and new, I'de attempt it but I have a feeling I may end up breaking something if I did it. There just isn't enough room for me to do it.
I can relax for a few days and forget about the car for the time being. I need a recharging. I have been at it for over a month many many hours a day.
I'm glad the fuel pressure was real low and how it bleed off fast after shut down. Because it means the problem has been identified and will be corrected as well as getting a 255 lph pump
But I knew this watching the PCM asking for more fuel in the fuel trims. When I set the tables to reflect the demand, it asked for more still and I added it again. Still was asking for more fuel, more fuel, more fuel. It just wasn't getting it. And the pressure from teh schrader valve was near nothing after a few minutes from shut down. I know I should've had a fuel pressure gauge but it was too obvious. Still getting the fuel pressure gauge soon for the dash, just to have it for future reference.
We all know how it goes. If I buy it I won't need it. If I don't buy it, I'll need it
That statement wouldn't surprise me though, since now with no bucket the pickup for the pump is a bit higher than the bottom of the tank, but since we have all those plastic things in our tank to prevent a lot of fuel movement, and that the return fuel is pumped right back into that location, it has prevented me from having an issue...Originally posted by 3400beretta View PostLOL yes Jon, like that.
I was just going by what many others have said before me, if you hack the bucket, then don't run below 1/4 tank.
If the W bodies don't have the bucket, then you can ignore the above.
But yes, typically I try to keep it above 1/4 anyways since I do know the pump is not at the BOTTOM of the tank, but about 1/4"-1/2" up.
Plus with that car's fuel usage, and my rural location a 1/4 tank may not get me to a gas station in time... LOL I say this as my red car is in the parking lot at 1/8th tank and I have a 22mile ride home.
At my current fuel usage though I only need 1 gallon to get it done.
1/4 tank on the Base cluster = empty. Z26 full gauges though it's not like that. I've ran it down to the red before. But I do want to say 1/4 tank with a stock pump that the car lacks balls. Just throwing in a few gallons when it's at 1/4 improves the performance WOT a lot, suggesting there is getting some air in the line when at 1/4 tank. When I ran 16.0 stock I had more than 1/4 tank and perhaps that is the reason I got a good time for being stock, as others might run 1/4 or less trying to save weight. That or my car is/was a factory freak compared to most 3100 L bodies... Mine would smoke my friends 96 Corsica...sigpic
THE PUMP IS IN!!!
I did it myself (pat on back) lol. And I didn't need to modify anything remarkably.
The tank is back in the car nice and tight. Only thing I have to do now is connect the filler tube and 3 other lines in the rear side. The front 3 lines are connected.
I also cleaned out the tank, wasn't hard. The pump filter was real clean but I used a new one anyways.
I had to stop after working an hour in the rain. Tomorrow I'll get the rest of the lines and filler up for a test pressurization then a test run.
It was a PITA but I did it. Ahhhh, I can relax knowing the rest is very easy stuff.
WOOHOO!!! I love that victory feeling!!!
edit: i know it isn't as big an accomplishment as a turbo install, but the working conditions made it a royal pita. Thats why I was so psyched. I had to do it outside in the driveway to get that little bit room from the pavement curve and for ventilation. Then it had to rain just as I had the tank under the car w/ new pump. My upper body was dry but my lower half was soaked.Last edited by Schmieder; 03-13-2010, 08:59 PM.
