Your main ground to the block, is it bolted to the trans bellhousing or the block itself? Test and see how much resistance you get from the battery - wire terminal to a cylinder head. Are there any non or poor conducting materials between the trans housing and the block?
Probably fine, though resisting grounds can cause issues.
If #5 is bad and #2 is good, that IS weird as both #2 & 5 should fail if either fails. They are opposing ends of the same coil inside. When one plug sparks to the ground, the other sparks from the ground in the opposite direction. pic
Checked the plug wire resistance yet?
Try running a new ground from the ICM to the batt-? To test the ground circuit.
Spark plug port threads coated or dirty on #5?
I doubt the 7x crank sensor is wired backwards as it would run even worse, if at all. But is worth checking. My VSS and 7xCKP pigtails are identical except for polarity.......if you custom wired, did you shield the crank sensor wire? Needs 12 twists per foot.
What about the wire which lets the PCM take control of spark from the ICM after start up?
A lot I mentioned I'm sure you know already.......just offering ideas, brain storming.
