What size is the hole on the 3400 heads?
300 hp N/A carb 2.8 V6 engine
I found a suitable fitting today.
"Reducer" , or what you call it.
I quess it is 1/8 NPT to 1/4 NPT ?
And there certainly was a 1/8 NPT thread in those 3400 heads , that I was using.
The thread was only in one cylinder head (for coolant temp sensor) , I had to make
the 1/8 NPT thread to the other head by myself (first drill a hole of course).
I need those fittings , because the water outlet is in different place in head , I think otherwise
there can remain air in the head .
"Reducing bushing"Originally posted by veekuusi View PostI found a suitable fitting today.
I quess it is 1/8 NPT to 1/4 NPT ?Current:
\'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
\'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
\'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
Gone, mostly forgotten:
\'90 Pontiac 6000 SE AWD: slow but invisible
I got the engine running all right.
But it made an interesting sound.
It took a while to figure out , what was wrong.
Starter motor gave up.
Bendix in the starter motor do not work.
The gear of the starter jammed to the fly wheel .
It takes a few days to get a new starter motor.
3400/newer style starter? Just put on a gear reduction myself and now have some teeth missing on the flexplate. Not sure if a shim would do anything for us. Bendix is not a cheap starter, my Airtex kind of was.95 Beretta 3100 with 3400 intakes and TCE TB
Grand Prix trans with 3.33FDR
Do you think it needed a shim or was it not lined up somehow? Or was it a bolt torque problem and the bolts came loose just enough to take it out of line? Hard to blame the starter, those two look the same.95 Beretta 3100 with 3400 intakes and TCE TB
You are right.Originally posted by ForcedFirebird View PostHow many engine starts did that starter have? seems premature.
Maybe hundreds of starts. There has been big difficulties to get the engine running in
the past few years.I mean long starting times. The starter has suffered a lot.
It has taken a beaten.
Certainly not loose bolts is the cause of the damage.
But now with the new starter, everything is OK.
