This thread is a continuation of this thread:
This story is to get a winning engine to a historic race car.
GM 2.8 V6 push rod engine in a 1974 Ford Capri.
-block 1996 3.1 (gen 3)FWD bore 89.25 , stroke 76 mm
-3400 aluminum heads (gen 3)
-custom billet Crower
-pistons Diamond custom
-Total Seal piston rings
-Manley stainless steel valves 1.76" / 1.42"
-camshaft Schneider 258/264 (.050") , lobe separation 106 , valve lift 13.2 mm (0.520")
-mechanical roller lifters (Crane)
-double custom valve springs closed 175 lbs, open 445 lbs
-roller rockers (Crane) 1.6:1
-custom push rods (Comp Cams)
-compression ratio 12:1
-Scat connecting rods 5.700"
-custom intake
-2 Weber 45 mm carbs
-ignition 6 x 034 Motorsport coils
-ECU Gems EM36
-spark plugs NGK BCR8ES
-custom exhaust 38 mm ID 3-> 1
-ATI damper
-electic water pump Davies Craig (EWP 115)
-dry sump AT-Power (3 stage)
-bellhousing Chevy S-10 5-speed (82-92)
-2 disc Alcon clutch
-gearbox 5-speed "dog box" Sellholm M47000
A had a total engine loss bacause of crankshaft cracked june 2014 (first race in this season).
Pretty much damage.
The race season 2014 was over.
I have in my garage all the other parts for the new engine except one.
The crankshaft.
The old one was original cast crank.
I ordered a new billet crankshaft from Crower.
I have not yet seen it ,
the latest news is that it should be ready "mid October".
There has been lots of enquirys, what is going on with this project.
I am sorry to put no input here in this forum.
But hopefully I have now time and motivation to go on ,
and we can see a better and winning engine in my car the race season 2015.
-custom intake
-ECU Gems EM36
-ATI damper
Pretty much damage.
The crankshaft.
