Sorry I just found thier site and now it says it is only a 80 hp gain. I think it is just rsmracing.com
300HP+
Kinda expensive. It comes with a vortec supercharger all the pulleys oil lines and shit and it comes with a k&n cone filter system and an exhaust system I'm pretty sure it is full exhaust and air intake, not sure if you get a chip too. You should check the site out man. www.rsmracing.com Go to grand am and you'll see all the mods you can get. Expensive thought and I've heard RSM can be pricks.
Holy geez..........
Porting the upper and lower intake can be done at home (if you have the skill). Taking it in some place will vary the price due to your location, who does the work, etc.
Ported heads are the same thing. Buying a set from some of the places that currently offer them is ridiculous. Expect to pay anywhere from $500-$1500 for an assembled set.
A 62mm throttle body will run you around $200 with an additional core charge of $100 or so (again, depending on where you go to get this). Keep in mind that if you get a bigger throttle body you will need to have the upper and lower intakes ported to see any gains.
Exhaust really depends on what you get. Headers will be $350+ for an uncoated set. Even then you will need to get them modified for your application unless you drive a 99+ GA.
Reprogrammed computer will run you $200+ and you have to send it to ASE or DHP to have it done.
So there you have it. For the porting work, I would contact some of your local places and see what they would charge you for the work. Sorry I don't have exact numbers for you, but it does vary depending on where you go, what you do, etc.
The RSM kit is even more ridiculous now... It is $5400 USD and it requires you to leave the car at their shop in Toronto for 6-8 weeks so that they can do the "custom" installation. So, not only do you have to shell out $5400, you also have to be without your car for 2 months AFTER you drive it up to Canada.-Brad-
