3100 (Gen 3) Specifications : LG8
  • 3100 (Gen 3) Specifications : LG8
    Application
    Specification
    Metric
    English
    General Data
    Engine Type
    60° V-6
    Displacement
    3.1L
    191 cu in
    RPO (VIN Code)
    L82 (M)
    Bore
    89 mm
    3.50 in
    Stroke
    84 mm
    3.31 in
    Deck Height
    224 mm
    8.818 in
    Compression Ratio
    9.5:1
    Firing Order
    1-2-3-4-5-6
    Oil Pressure
    103 kPa
    15 psi @ 1100 RPM
    Cylinder Bore
    Diameter
    89.016-89.034 mm
    3.5046-3.5053 in
    Out Of Round Maximum
    0.014 mm
    0.0005 in
    Taper -- Thrust Side Maximum
    0.020 mm
    0.0008 in
    Piston
    Diameter-Gaged on the skirt 12 mm below the centerline of the piston pin bore
    88.974-89.001 mm
    3.5029-3.5040 in
    Clearance
    0.032-0.068 mm
    0.0013-0.0027 in
    Pin Bore
    23.006-23.013 mm
    0.9057-0.9060 in
    Piston Ring
    Top Groove Side Clearance
    0.05-0.085 mm
    0.002-0.0033 in
    Second Groove Side Clearance
    0.05-0.09 mm
    0.002-0.0035 in
    Top Ring Gap
    0.15-0.36 mm
    0.006-0.014 in
    Second Ring Gap
    0.5-0.71 mm
    0.0197-0.0280 in
    Groove Clearance
    0.20 mm
    0.008 in in
    Gap with segment at 89.0 mm
    0.25-1.27 mm
    0.0098-0.05 in
    Piston Pin
    Diameter
    22.9915-22.9964 mm
    0.9052-0.9054 in
    Clearance In Piston
    0.0096-0.0215 mm
    0.0004-0.0008 in
    Fit In Rod
    0.0165-0.0464 mm
    0.0006-0.0018 in
    Crankshaft
    Main Journal Diameter
    67.239-67.257 mm
    2.6473-2.6483 in
    Main Journal Taper
    0.005 mm
    0.0002 in
    Out Of Round
    0.005 mm
    0.0002 in
    Flange Runout-Max
    0.04 mm
    0.0016 in
    Cylinder Block Main Bearing Bore Diameter
    72.155-72.168 mm
    2.8407-2.8412 in
    Crankshaft Main Bearing Inside Diameter
    67.289-67.316 mm
    2.6492-2.6502 in
    Main Bearing Clearance
    0.019-0.064 mm
    0.0008-0.0025 in
    Main Thrust Bearing Clearance
    0.032-0.077 mm
    0.0012-0.0030 in
    Crankshaft End Play
    0.060-0.210 mm
    0.0024-0.0083 in
    Crankshaft Flange Runout-Max
    0.04 mm
    0.0016 in
    Crankpin
    Rod Bearing Journal Diameter
    50.768-50.784 mm
    1.9987-1.9994 in
    Rod Bearing Journal Taper
    0.005 mm
    0.0002 in
    Rod Bearing Journal Out Of Round
    0.005 mm
    0.0002 in
    Rod Bearing Bore Diameter
    53.962-53.984 mm
    2.124-2.125 in
    Rod Inside Bearing Diameter
    50.812-50.850 mm
    2.000-2.002 in
    Rod Bearing Journal Clearance
    0.018-0.062 mm
    0.0007-0.0024 in
    Rod Side Clearance
    0.18-0.44 mm
    0.007-0.017 in
    Camshaft
    Lobe Lift (Intake and Exhaust)
    6.9263 mm
    0.2727 in
    Journal Diameter
    47.45-47.48 mm
    1.868-1.869 in
    Camshaft Bearing Bore Diameter-Front and Rear
    51.03-51.08 mm
    2.009-2.011 in
    Camshaft Bearing Bore Diameter-Middle #2 and #3
    50.77-50.82 mm
    1.999-2.001 in
    Camshaft Bearing Inside Diameter
    47.523-47.549 mm
    1.871-1.872 in
    Journal Clearance
    0.026-0.101 mm
    0.001-0.0039 in
    Journal Runout-Max
    0.025 mm
    0.001 in
    Valve System
    Roller Lifter
    Hydraulic
    Rocker Arm Ratio
    1.60:1
    Valve Face Angle
    45°
    Seat Angle
    45°
    Valve Seat Runout
    0.025 mm
    0.001 in
    Seat Width-Intake
    1.55-1.80 mm
    0.061-0.071 in
    Seat Width-Exhaust
    1.70-2.0 mm
    0.067-0.079 in
    Valve Margin - Minimum Intake
    2.10 mm
    0.083 in
    Valve Margin - Minimum Exhaust
    2.70 mm
    0.106 in
    Valve Stem Clearance
    0.026-0.068 mm
    0.0010-0.0027 in
    Valve Spring
    Valve Springs Free Length
    48.5 mm
    1.89 in
    Valve Springs Load (Closed)
    320 N @ 43.2 mm
    75 lb @ 1.701 in
    Valve Springs Load (Open)
    1036 N @ 32 mm
    230 lb @ 1.260 in
    Installed Height Intake-Exhaust
    43.2 mm
    1.701 in
    Approx. # or coils
    6.55
    Oil Pump
    Gear Lash
    0.094-0.195 mm
    0.0037-0.0077 in
    Gear Pocket Depth
    30.52-30.58 mm
    1.202-1.204 in
    Gear Pocket Diameter
    38.176-38.226 mm
    1.503-1.505 in
    Gear
    Length
    30.45-30.48 mm
    1.199-1.200 in
    Diameter
    38.05-38.10 mm
    1.498-1.500 in
    Side Clearance
    0.038-0.088 mm
    0.001-0.003 in
    End Clearance
    0.040-0.125 mm
    0.002-0.005 in
    Valve to Bore Clearance
    0.038-0.089 mm
    0.0015-0.0035 in
    Fastener Tightening Specifications (LG8 and LA1)
    Application
    Specification
    Metric
    English
    Accelerator Control Cable Bracket Bolt/Nut
    10 N·m
    89 lb in
    Camshaft Position Sensor Bolt
    10 N·m
    89 lb in
    Camshaft Sprocket Bolt
    140 N·m
    103 lb ft
    Camshaft Thrust Plate Screw
    10 N·m
    89 lb in
    Connecting Rod Bearing Cap Nut
    20 N·m + 75°
    15 lb ft + 75°
    Coolant Drain Plug
    19 N·m
    14 lb ft
    Coolant Temperature Sensor
    23 N·m
    17 lb ft
    Crankshaft Balancer Bolt
    103 N·m
    76 lb ft
    Crankshaft Main Bearing Cap Bolt/Stud
    50 N·m +77°
    37 lb ft + 77°
    Crankshaft Oil Deflector Nut
    25 N·m
    18 lb ft
    Crankshaft Position Sensor Bolt -- Front Cover
    10 N·m
    89 lb in
    Crankshaft Position Sensor Stud -- Side of Engine Block
    11 N·m
    98 lb in
    Crankshaft Position Sensor Wiring Bracket Bolt
    27 N·m
    20 lb ft
    Cylinder Head Bolt
    60 N·m + 95°
    44 lb ft + 95°
    Drive Belt Shield Bolt
    10 N·m
    89 lb in
    Drive Belt Tensioner Bolt
    50 N·m
    37 lb ft
    EGR Valve to EGR Valve Pipe Bolt
    25 N·m
    18 lb ft
    EGR Valve Adapter Pipe to Exhaust Manifold Nut
    25 N·m
    18 lb ft
    Engine Flywheel Bolt
    71 N·m
    52 lb ft
    Engine Front Cover Bolt -- Large
    55 N·m
    41 lb ft
    Engine Front Cover Bolt -- Medium
    47 N·m
    35 lb ft
    Engine Front Cover Bolt -- Small
    21 N·m
    15 lb ft
    Engine Mount Bracket Bolt
    58 N·m
    43 lb ft
    Engine Mount Lower Nut
    43 N·m
    32 lb ft
    Engine Mount Strut and Lift Bracket Bolt -- Engine Left Rear
    70 N·m
    52 lb ft
    Engine Mount Strut Bolt/Nut
    48 N·m
    35 lb ft
    Engine Mount Strut Bracket Bolt -- Upper Radiator Support
    28 N·m
    21 lb ft
    Engine Mount Strut Bracket Bolt -- Vehicle Right Side
    50 N·m
    37 lb ft
    Engine Mount Upper Nut
    47 N·m
    35 lb ft
    Engine Oil Pressure Indicator Switch
    13 N·m
    115 lb in
    Engine Wiring Harness Bracket Bolt
    13 N·m
    115 lb in
    Exhaust Crossover Pipe Heat Shield Bolt
    10 N·m
    89 lb in
    Exhaust Crossover Pipe Nut/Stud
    25 N·m
    18 lb ft
    Exhaust Manifold Heat Shield Bolt
    10 N·m
    89 lb in
    16 N·m
    12 lb ft
    Exhaust Manifold Stud
    18 N·m
    13 lb ft
    Fuel Feed Pipe to Fuel Injector Rail Nut
    17 N·m
    13 lb ft
    Fuel Injector Rail Bolt
    10 N·m
    89 lb in
    Fuel Pipe Bracket Bolt/Stud
    50 N·m
    37 lb ft
    Fuel Pipe Clip Bolt
    8 N·m
    71 lb in
    Fuel Return Pipe to Fuel Injector Rail Nut
    17 N·m
    13 lb ft
    Generator Bracket and Front Engine Lift Hook Bolt
    50 N·m
    37 lb ft
    Heated Oxygen Sensor
    42 N·m
    31 lb ft
    Heater Inlet Pipe Nut
    25 N·m
    18 lb ft
    Ignition Coil Bracket Bolt/Nut/Stud
    25 N·m
    18 lb ft
    Intake Manifold Coolant Pipe Bolt
    10 N·m
    89 lb in
    Knock Sensor
    19 N·m
    14 lb ft
    Lower Intake Manifold Bolt - Center
    • First Pass
    7 N·m
    62 lb in
    • Final Pass
    13 N·m
    115 lb in
    Lower Intake Manifold Bolt - Corner
    • First Pass
    13 N·m
    115 lb in
    • Final Pass
    25 N·m
    18 lb ft
    MAP Sensor Bolt
    5 N·m
    44 lb in
    Oil Cooler Connector
    50 N·m
    37 lb ft
    Oil Cooler Hose Fitting
    19 N·m
    14 lb ft
    Oil Cooler Pipe Bracket Bolt
    10 N·m
    89 lb in
    Oil Filter
    13 N·m
    115 lb in
    Oil Filter Bypass Hole Plug
    19 N·m
    14 lb ft
    Oil Filter Fitting
    39 N·m
    29 lb ft
    Oil Gallery Plug -- 1/4 inch
    19 N·m
    14 lb ft
    Oil Gallery Plug -- 3/8 inch
    33 N·m
    24 lb ft
    Oil Level Indicator Tube Stud
    25 N·m
    18 lb ft
    Oil Level Sensor Bolt
    10 N·m
    89 lb in
    Oil Pan Bolt
    25 N·m
    18 lb ft
    Oil Pan Drain Plug
    25 N·m
    18 lb ft
    Oil Pan Side Bolt
    50 N·m
    37 lb ft
    Oil Pump Cover Bolt
    10 N·m
    89 lb in
    Oil Pump Drive Clamp Bolt
    36 N·m
    27 lb ft
    Oil Pump Mounting Bolt
    41 N·m
    30 lb ft
    Spark Plug
    • Spark Plug - Initial Installation
    20 N·m
    15 lb ft
    • Spark Plug - Reinstallation
    15 N·m
    11 lb ft
    Thermostat Bypass Pipe to Cylinder Head Nut
    25 N·m
    18 lb ft
    Thermostat Bypass Pipe to Engine Front Cover Bolt
    12 N·m
    106 lb in
    Thermostat Bypass Pipe to Throttle Body Nut
    25 N·m
    18 lb ft
    Throttle Body Bolt/Stud
    25 N·m
    18 lb ft
    Timing Chain Dampener Bolt
    21 N·m
    15 lb ft
    Upper Intake Manifold Bolt/Stud
    25 N·m
    18 lb ft
    Valve Lifter Guide Bolt
    10 N·m
    89 lb in
    Valve Rocker Arm Bolt
    19 N·m + 30°
    14 lb  ft+ 30°
    Valve Rocker Arm Cover Bolt
    10 N·m
    89 lb in
    Water Outlet Bolt
    25 N·m
    18 lb ft
    Water Pump Bolt
    10 N·m
    89 lb in
    Water Pump Pulley Bolt
    25 N·m
    18 lb ft
      Posting comments is disabled.
    Article Tags
    There are no tags yet.
    Latest Articles
    • Assembly Fluids
      by SappySE107
      This is for the 2004 Grand Am 3400, but should be good for all.
      10-11-2026, 10:05 PM
    • Aftermarket 3500 LX9 Lower Intake Gaskets
      by SappySE107
      If you are replacing the lower intake gaskets for whatever reason, its most likely going to be a metal and rubber gasket, like this.
      which is great, if you only want it to seal. If you want it to make the power it use to, then you need to remove some of that rubber, like this.
      Then you throw it on a flowbench (or take my word for it since I did this step for WOT-Tech)
      And see what the flow difference is.
      03-22-2024, 01:40 AM
    • 3x00 Exploded View
      by bszopi
      Click on a number corresponding to the part you are looking for information on. This will load a new page with detailed information (part numbers, specifications, description, etc) for the part. This is a general breakdown of parts. With that said, there may be some parts not shown that are on a specific platform. There may also be some parts that are shown that are not on all platforms. Several items vary over the years as well, and any variances should be covered in the detailed description pa...
      10-06-2010, 11:46 PM
      by bszopi
      06-15-2010, 04:48 PM
    • 3100 (Gen 3) Specifications : L82
      by bszopi
      06-15-2010, 04:42 PM
    • Pushrod Location
      by SappySE107
      Pushrods are valve specific on all Gen 2 and newer pushrod motors. The following are when you are standing in front of the radiator, looking at the engine. In a FWD configuration the order for the rear head from left to right is Exhaust, Intake, Exhaust, Intake, Intake, Exhaust. The front head from left to right is Exhaust, Intake, Exhaust, Intake, Intake, Exhaust. If you are working with a RWD configuration, the left head from front to back is Exhaust, Intake, Exhaust, Intake, Intake, Exhaust...
      04-13-2010, 08:10 PM
