Plans for L32/3X00 Hybrid
  • tkoforpresident
    Max
    • Feb 2009
    • 710
    #181
    OK, well nobody knows the answers.
    That's cool. I'll just measure the ports myself and see if there is a difference.
    93 Firebird 3.4
    • WrathOfSocrus
      • Jan 2008
      • 318
      #182
      The 3500 ports are SMALLER on the LIM than a 3400. A while back I made the mistake of slightly widening the 3400 UIM before even looking at the 3500 LIM and had to port it out quit a bit to match. Luckily I didn't go crazy on the UIM.
      As for the gasket, you should be able to trim it up a bit. You can line it up to your TB with the bolts and press against the edge and that gives u a line to follow. Or if you have the throttle plate out you could probably mate it to the UIM on a bench and carefully go around with a knife to cut off what sticks into the opening.
      • tkoforpresident
        Max
        • Feb 2009
        • 710
        #183
        Wow so the 3500 lim will have to be opened up to match the 3400 upper? I would have guessed the other way around. Thx for the intel.
        93 Firebird 3.4
        • WrathOfSocrus
          • Jan 2008
          • 318
          #184
          Fixed my post but you got it right. I'm not sure how far off the measurement is , but after seeing the difference in size I compared it to the 3400 LIM I noticed the difference. If you don't want to go crazy with porting you can bevel the edge and just blend it down a bit. As long as the air doesn't hit a sharp obstruction it should flow alright.
          When I opened mine up I used some cardboard (have also used left over gasket material that comes in a sheet for around $6, seems to form better) lined it up to the UIM, and pushed a screwdriver through where the bolts go and dropped the bolts in place. I pressed down along the edges of the ports to see the outline and cut it open with a razor. Then I went to the LIM and put down a couple strips of duct tape. Lined up the cardboard and carefully traced it into the tape with a razor. The duct tape is a life saver in case u slip while porting because it catches the file or burr before the mating surface gets damaged. Once you have your outline u can bevel the edge back at a rough 45* and then decide how much effort you want to put in to blending it down.
          I looked back briefly and saw your LIM looks like it is not ported. If your UIM is not ported then you probably don't have much material to remove. I think the reason the 3500 ports start out smaller is because the way the 3500 UIM is larger inside without runners, then gets sucked down the smaller port it increases velocity.
          • tkoforpresident
            Max
            • Feb 2009
            • 710
            #185
            Yeah I don't want to port it so much but rather make the intakes uniform so flow isn't compromised. Either way I'm sure the setup I end up with will be twice as good as my old 3.4 intakes. Those things are a joke.
            93 Firebird 3.4
            • TechRod
              Destruction Worker
              • Feb 2009
              • 162
              #186
              Ain't that the truth.
              "It's your car. Do with it what you wish, but as you enter this unknown world you will need to invent the wheel all over again. For the adventurous and those that are backyard mechanics who have nothing but time you might like this. Most have plenty of frustrating moments and the process usually takes significantly longer then what anyone could imagine. The end result of this conversion is completely up to you." - Jon McCullough of BMCautos.com
              • tkoforpresident
                Max
                • Feb 2009
                • 710
                #187
                I took the time yesterday to grind off the letters/numbers from the top of the 3400 upper intake. I also dropped it off at a friends house to have it slightly ported/smoothed to match my 59mm TB. Once he's done with it I can clean it, paint it, bolt up the TB/egr block off plate, and get some pics for you guys.
                Should look good, especially with the black powdercoated tb, and stainless steel bolts.
                93 Firebird 3.4
                • tkoforpresident
                  Max
                  • Feb 2009
                  • 710
                  #188
                  https://http://i555.photobucket.com/albums/j...g?t=1339893628
                  https://
                  https://
                  93 Firebird 3.4
                    what's that?
                    progress?
                    you remind me of my own stuff that sorely needs to be completed.
                    • tkoforpresident
                      Max
                      • Feb 2009
                      • 710
                      #190
                      Yup. I've got the itch again.... hehe
                      time to contact Benny Boy
                      93 Firebird 3.4
                      • TechRod
                        Destruction Worker
                        • Feb 2009
                        • 162
                        #191
                        Lookin good!
                        • tkoforpresident
                          Max
                          • Feb 2009
                          • 710
                          #192
                          thx man!
                          93 Firebird 3.4
                            Live life 3.7mi at a time
                            • 4555
                            #193
                            Glad to see you back at it, Max!
                            • tkoforpresident
                              Max
                              • Feb 2009
                              • 710
                              #194
                              thx John
                              I'm gonna need some parts from you soon.
                              93 Firebird 3.4
                              • tkoforpresident
                                Max
                                • Feb 2009
                                • 710
                                #195
                                Trying to figure out the whole TB cable setup.
                                I have an auto trans but I don't really care if I keep the cruise control.
                                There are three cables that currently go to my 3.4 TB. Which ones definitely NEED to be hooked up to the new 3400 TB?
                                Obviously the actual throttle cable, which I've been told there is a direct fit for me from a trail blazer (John still needs to give me the part #)
                                But what about the other two?
                                93 Firebird 3.4
