Cam Specs
  • 93GAGT3300
    • 35
    great, try these configurations. the test car would be my 96 ga gt 3100. stock ported heads, 01 malibu uim, and lower intake manifold, 96 pcm & injectors, exhaust system planned to be redone
    type 1 // .394 intake lift/.410 exhaust lift. intake duration is 276.
    196 degrees @.050. exhaust duration 293. 203 degrees @.050. lobe centerline 114
    type 2// .427 intake lift/.454 exhaust. intake 204 degrees @.050. exhaust 216 degrees @.050 lobe separation is 107
    type 3// same as above with 112 lobe separation.
    thanks, just curious to see what these would produce......
    • geldartb
      The Situation
      • May 2004
      • 1994
      would i be able to have a cam ground in 1386. and how much would that end up costing. think the last time i saw the store it was something like 300.
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        • 13531
        It will probably end up closer to 220/220 duration but that grind can be done. Its 300 plus shipping for any cam with grind on the store.
        • geldartb
          The Situation
          • May 2004
          • 1994
          thats fine ill be hitting you up in a few weeks for one.
          99 Grand Am GT
            • 13531
            I have the new spec sheet with more grinds available. I made a spreadsheet in excel for now so that everyone can read it.
            • gectek
              Banned
              • Aug 2006
              • 1472
              #21
              on those cam specs, can they adjust lift on a certain grind, say you want the 1312 grind to have more intake lift, can they do that?
                • 13531
                #22
                I will have to ask on the specifics per grind. I know there is a limit with how much they can go depending on the duration and LSA change.
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  #23
                  well there isnt any LSA change and the dur isnt much either with the 1312 grind being 112 LSA, 206/210 on dur, its not much, i just want about .500 lift on int and the .507 on ext. just to up the breathing a bit more on the intake, up from .475
                    • 13531
                    #24
                    I called them today and its a no go on custom specs. They have to have a master to copy so it will be about 800 to add my own custom grinds Sucks cause I have the perfect boost cam designed but I can't get it ground unless I had enough interest to make a batch of them.
                      • 13531
                      #25
                      Bump:P
                      http://60degreev6.com/store/images/Cam/CamSpecs.htm
                      • geldartb
                        The Situation
                        • May 2004
                        • 1994
                        #26
                        after looking at the sheet. what would you recomend for a setup that consists of this
                        3.4 rwd pistons and head gaskets
                        3400 block
                        3400 ported topend with ls6 springs
                        Bore 3.622"
                        Stroke 3.307"
                        Head Gasket Bore 3.75"
                        Head Gasket Compressed Thickness .040"
                        Combustion Chamber Volume 36.0 cc
                        Piston Dome Volume 8.0 cc
                        Piston Deck Clearance .0095"
                        Displacement 3349 cc
                        Calculated Compression Ratio 11.56:1
                        99 Grand Am GT
                          • 13531
                          #27
                          What powerband? Redline?
                          • geldartb
                            The Situation
                            • May 2004
                            • 1994
                            #28
                            powerband id like decent low end and a good top end so it wont fall on its face before 6k. cant really see a reason to go above that.
                            as for redline ill stick with the stockish redline.
                            99 Grand Am GT
                              • 13531
                              #29
                              I left my USB key at the machine shop, but I will run some simulations tomorrow. I think I know which grind for that but I didnt write it down when I was messing with it originally.
                              • geldartb
                                The Situation
                                • May 2004
                                • 1994
                                #30
                                cool. thank you. in like a month or so ill be getting it from you.
                                99 Grand Am GT
