Cam Specs
    • 13533
    #31
    Updated with stock 3400 motor simulations for the cam specs. This might help you get an idea of what the cam does. I will simulate other modifications as well and make packages to suit the cam for each application. This was the first step.
    http://www.60degreev6.com/store/inde...d&productId=70
    • geldartb
      The Situation
      • May 2004
      • 1994
      #32
      was looking at a few of them and im leaning towards this one
      1615 231 234 281 283 111 110 112 379 352 606 563
      do you think it would work good with this setup
      3.4 rwd pistons and head gaskets
      3400 block
      3400 ported topend with ls6 springs openening the cc chanmber up
      Bore 3.622"
      Stroke 3.307"
      Head Gasket Bore 3.75"
      Head Gasket Compressed Thickness .040"
      Combustion Chamber Volume 36.0 cc
      Piston Dome Volume 8.0 cc
      Piston Deck Clearance .0095"
      Displacement 3349 cc
      Calculated Compression Ratio 11.56:1
      99 Grand Am GT
      1357 cam 227 233 .050 dur
      515 515 lift 112 lsa
        • 13533
        #33
        Stock 3400, 3400 with stock 3500 top end, 3400 with street ported 3500 top end, and 11.5:1 compressoin 3400 with street ported 3500 top end. That should cover a wide range now. For specific applications, I will work with customers to get the right setup. I cannot possibly simulate everyone's ideas. I will try to make an easier comparison later as well as list the recommendation for each cam. This should allow me to make dynamic packages per application.
        http://www.60degreev6.com/store/imag...V6regrinds.htm
        • geldartb
          The Situation
          • May 2004
          • 1994
          #34
          thank you. its looks like its going to make a sweet combo. cant wait to get this thing in the engine. now i need 460 bucks. i like the option for custon pushrods too. ill most likely be getting those too.
          99 Grand Am GT
            • 13533
            #35
            You are going to need the comp 26986 springs or some head modiciation to run that much lift. I haven't checked to see exactly when the retainer hits the valve stem seal. Might be getting close to that too.
            • geldartb
              The Situation
              • May 2004
              • 1994
              #36
              well it was either going to be that one or a better choice you could recomend. ive got ls6 springs right now if that matters.
              im open to opinions for what would work good.
              99 Grand Am GT
                • 13533
                #37
                I wouldn't go over .539 lift and would rather only go to about .520 lift on LS6 springs. If you machined the spring seat area down, then they would be fine.
                • geldartb
                  The Situation
                  • May 2004
                  • 1994
                  #38
                  didnt have anything machined down under the spring.
                  with that advice given the 1357 grind is looking good for lift.
                  99 Grand Am GT
                  • mfuller
                    Mr. Common Sense
                    • Nov 2003
                    • 374
                    #39
                    Here's another question: how big of a cam can you go before you need gears and/or a converter to make it worthwhile?
                    I.E. Could I safely run a 1393 grind with my factory converter and 3.05 diff?
                    Matt
                    • gectek
                      Banned
                      • Aug 2006
                      • 1472
                      #40
                      that one would be no prob with ur diff, it will actually give u better bottom and the dur isnt much to worry about...only higher dur like the 216 and up into the 220-230 range would i worry about gears to take up the slack in the bottom end
                      • RedBird
                        Aka Mr. 5th Motor
                        • Sep 2006
                        • 426
                        #41
                        So.....um.....where did the cam regrinds in the store go?!?!? I was in there just now to buy my cam(1617) and they're gone!?
                        Cammed 3400 --> 224whp 210wtq
                        Cammed 3500 --> ???
                        1 of 5 3500 J-Bodies
                          • 13533
                          #42
                          under valvetrain
                          • RedBird
                            Aka Mr. 5th Motor
                            • Sep 2006
                            • 426
                            #43
                            Yea, damnit, i was hoping to edit my post before someone replied to it. I'm an idiot LMAO.
                            Ordering now
                            Cammed 3500 --> ???
                            • RedBird
                              Aka Mr. 5th Motor
                              • Sep 2006
                              • 426
                              #44
                              Well, cam is in. Hopefully i'll have a video clip of what this cam sounds like in 2-3 weeks.
                              Cammed 3500 --> ???
                                • 13533
                                #45
                                sweet Post it on our gallery when you do.
