Underdrive pulley with damper for 3400
    • 13530
    #121
    Just buy the MRZ anyway if you don't care about the damper. I don't consider anything without the damper in place to be an option. That is what this whole discussion is about.
      Originally posted by ixion View Post
      Not a bad idea. Considering the MRZ pulleys are $135 +shipping, and a matching alternator pulley is $55 +shipping, that already puts a buyer at the proposed ~$200 price point of Powerbond ... for just an UDP at only 10% reduction (as opposed to MRZ's ~15%).
      I say let Powerbond worry about making a 25% smaller stock pulley. The people that want to stay SFI for mild performance with better daily drive-ability can buy from MRZ. Just my $.02
      Its not JUST an UDP... its a 10% reduction UDP with a dampener... that is why they can't go smaller. It may just come down to it that there is NO room to go smaller due to the rubber ring dampener, without sacrificing something important. And I find SFI to be important on my car... MUCH less fuel consumption when I drive it around town.
      After what I have seen done to timing sets from a UDP with no dampener I will never install one on my car again. I'll stick with stock, and not have to worry about low charge at idle and such.
      • discostu
        • Jul 2005
        • 105
        #123
        Umm the rubber ring is like 1/4" thick. I think the problem with going 25% is the way they want to incorporate the SFI tone ring, not the rubber ring.
          I'm referring to the comparison between MRZ's 15% and this ones 10%. You can't get 15% reduction AND a rubber ring in there which ALSO has the tone ring for the sensor... there is just no room.
          I know that 25% is out of the question for a SFI application, and maybe even a FWD application... I don't even know if that would leave enough room in the back to fit where it goes around the oil pan.
          In comparison to many pulley applications, OURS is already pretty small, as far as material AFTER the rubber dampener and the space between the inside cut out and the rubber ring... now if there was a lot of excess material in those areas then yes a large reduction is possible, but since there isn't all that much there to begin with then you cant reduce it by much without rendering it useless.
          Same idea as the water pump under-drive pulley... that would counter act reduction done by the crank and prevent over heating... Its not possible with the way the pulley is wrapped around the pump housing... You can't even really go with a large one on a L-body with the way the motor mount sits in there.
          Look how little material there is between the rubber ring and where the cutouts are for the center of the pulley... there's nothing, so you can make that part any smaller since the inner diameter is the spacing of where the 24x sensor is positioned...
          You can only take off whats after that ring... measure it and do the math, I bet its between 10 and 15% of the overall diameter.
          Also see how you can't go larger on a WP pulley to counter act a small crank pulley.
          Some of this stuff is almost already as small as you can go without causing interference or issues with electronic controls... Could you relocate the 24x sensor? Of course... but do you want to? Probably not since its not going to gain you a ton of power.
          • RedBird
            Aka Mr. 5th Motor
            • Sep 2006
            • 426
            #125
            i guess it just depends on what powerbond thinks about the situation. anything pre-'94(and '94 j-bodies) could use one without the tone ring, and if they could make one at 25% reduction without the tone ring, that's their target group. And those cars are getting fewer every day.
            BUT, there's probably a lot more people on '94-'05 OBDII that need that tone ring to run the car at low rpms.
            I'm thinking that as much as i'd like to see a 25% reduction crank pulley, it's not going to happen unless they design a second pulley. which who knows, they might. GM doesn't use the tone ring in the pulley anymore, eveyrthing is integrated into the 57x crank trigger, and the cam sensor. i guess we'll just have to see what they decide to do.
            Cammed 3400 --> 224whp 210wtq
            Cammed 3500 --> ???
            1 of 5 3500 J-Bodies
            • discostu
              • Jul 2005
              • 105
              #126
              What's the good word on these underdrive damper pulleys?
                So complete honesty here... Did I give away my FFP UDP for free for nothing?
                It sounds like this project is DEAD... I would at least like my pulley back so I can sell it elsewhere, OR I would like some money for it.
                I did not expect to never see it or progress on this again.
                • gectek
                  Banned
                  • Aug 2006
                  • 1472
                  #128
                  The problem with talking to a company that is half a world away, is the fact that they are half a world away. I send them an email, it takes at least a day before they read it and then maybe longer before they respond. I will try to find something out as soon as possible.
                    Thank you gectek
                    • discostu
                      • Jul 2005
                      • 105
                      #130
                      Any update on these pullies?
                      • Nick-G
                        11's or Bust...
                        • Feb 2008
                        • 224
                        #131
                        I'm hoping this idea hasn't died. Here is a good read for those of you using aluminum pulleys. http://grandamgt.com/forum/showthread.php?t=83221
                        • torq455
                          If I only had money!!!
                          • Dec 2003
                          • 1615
                          #132
                          they aluminum pulleys should have a steel sleeve on that part to prevent the wear. mine does (FFP).
                          Andy
                          fastest 1/8: 10.19@ 67.17
                          fastest 1/4: 16.16@ 82.70
                          • Nick-G
                            11's or Bust...
                            • Feb 2008
                            • 224
                            #133
                            I also have a FFP pulley. This only effects the RSM pulley and possibly MRZ? Maybe someone else can confirm wheather or not the MRZ pulley has the steel hub.
                              MRZ has the insert. I spoke with him about this during his design phase and he incorported it. He originally wasn't going to till I spoke up in one of his threads on Bstuff IIRC.
                                Yep, only the RSM and i think early FFP's.
                                my old FFP had it, never had any leaks.
