Cometic Head Gaskets $139.99
    • 13533
    Cometic MLS Head Gaskets will be available the 3rd week of October (they are tooling up for them now). Available in any bore and thickness, though stock bores are listed with a thickness range of .040" to .080" for the 2.8/3.1/3100, 3400, 3500, and 3500/3900 VVT engines.
  • gectek
    Banned
    • Aug 2006
    • 1472
    impressive indeed. new swag
    • Nick-G
      11's or Bust...
      • Feb 2008
      • 224
      Can't wait to get my hands on a set of these.
      BUILT Turbo 3400/4t65e-HD powered Grand AM in the making.
        • 13533
        Until they are available, the following code will get you $15 off
        Cometic
        I would like to see a good size order by the time they are available.
        • gectek
          Banned
          • Aug 2006
          • 1472
          Are they on the site yet to buy? all i see is the update...lol. No rush.
            • 13533
            The update has links to each listing. I didn't put them all in the recent products at the bottom.
            • gectek
              Banned
              • Aug 2006
              • 1472
              im a moron. HAR
                • 13533
                Let me know if that listing and the linked article are good. I am going to work on a table for the compression/thickness. The bore doesn't do a heck of a lot to the compression. Any feedback is appreciated.
                • ssdurango
                  • Dec 2004
                  • 170
                  Great! The day after I replace my blown head gaskets with $150 GM gaskets, These become available!!
                  • gectek
                    Banned
                    • Aug 2006
                    • 1472
                    who did you get them through? jeebus!
                    Sorry, but the page you are looking for no longer exists. If you have any questions or can't find what you are looking for, please contact us . SD Parts Support
                    single head gasket
                    head set
                    now i understand if you paid that for the head set, but not just some head gaskets.
                    • ssdurango
                      • Dec 2004
                      • 170
                      Just the gaskets...that was Canadian dollars including tax.
                      • gectek
                        Banned
                        • Aug 2006
                        • 1472
                        well still. i know its not us dollar x2...
                        • barrok69
                          • 34
                          If I'm getting my block bored 20 over for forged pistons will the "standard size" gasket still fit? or do i need to get the +.020" bore size gasket. The only reason I ask is typically gaskets are usually a bit bigger than the actual bore size. Any suggestions?
                          -=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
                          14.99@91.33mph
                            • 13533
                            You should get them .020" larger than default. I have them at .020" larger than the stock bore, unlike the stock head gaskets that are .130" larger than the stock bore.
                              That would be a nice displacement boost if you had the bore match the cylinder... So in theory, these gaskets would slightly increase compression as well (unless you got thicker ones), correct?
