moates ZIF
  • 95SleeperAcheiva
    ArtofOlivia"PocketRocket"
    • Jun 2006
    • 694
    moates ZIF
    could I get a price or option.....
    I have a 1227730 ECU going into my '95 achieva. I got the ecu from a junk yard donor corsica circa '92, v-6. that's all i got for info on donor.
    I would like a swap chip with the "3400 swap chip" burn on it with automatic and the moates version with the ZIF. I'm not really concerned with shift points, I plan on flashing them way off the board and doing all manual shifting, hence I'm swapping the valve body from a grand prix so I can get 1st gear at the shifter.
    So do I buy the chip and send it to you from moates or can you get it and burn it, then send it to me?
    side note, all track only. ecu has no control over fuel pump or fans, no emissions, heavy port and polish work, 75mm TB, 110 stat, 5k stall converter, no accessories ie no water pump, PS, a/c, cruise, abs, SRS, etc, all gone.
    As you can see I missed a year of racing and have been a busy boy.
    • 13525
    Do you want just a chip, chip and adapter, or chip with adapter with zif? The only part I don't have here is the ZIF.
    • 95SleeperAcheiva
      • Jun 2006
      • 694
      chip with adapter with zif.
        • 13525
        I can do chip and adapter. You will have to go to moates for the ZIF.
