Are lifters generally replaced during a rebuild?
  • dykz34
    • Jan 2004
    • 793
    Is it common for them to be replaced when a motor is rebuilt? Or are they only replaced if they are bad?
  • LQ1
    • Apr 2004
    • 151
    Id say if they are bad or if there is a new cam going in.
    www.cardomain.com/id/topless94style
    • 4spdz34
      • 185
      depends on mileage. but u should always check them. i'm sure there is a spec on them somewhere
      • Lyle's GTP
        • Jan 2004
        • 1345
        When I was at Optimax we junked every one.
        Lyle
        • Anonymous
          When I did my motor, they kept the lifters. But I had to replace the valves/springs becuz of mileage. They said using Mobil 1 saved me about a thousand dollars worth of cams, lifters, and some other things.
            Not to drag up an old post, but I just checked out the lifters in the 92 (previous owner ran Mobil 1 after 30k miles, and I continued using it after I got it) and I have to say the lifters are incredible looking. Most lifters from other DOHC run w/ standard oil have scratches like crazy on the sides where they slide in the bore. Each one of mine barely have any at all. All I can say is I am impressed.
            • bud36light
              • Nov 2003
              • 517
              Man live by the ol rule, replace the cam replace the lifters.
              2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
              • dbtk2
                • Feb 2004
                • 349
                I'm pretty sure you're not supposed to replace the lifters if you're not replacing the cam, and if you replace the cam you MUST get new lifters. So if you're not pulling the cam, leave the lifters alone unless they look damaged.
                Shawn
                99 Grand Prix GT
                • Anonymous
                  I used my old cams and lifters, with new valves/valve springs
                    • 13519
                    It doesnt apply to DOHC because the pressure isnt as great on them as it is for the pushrods. Large area = less wear. You can replace lifters without replacing a cam though...if you couldn't that would be retarded for when a lifter collapses.
