FLOWBENCH FUND
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    FLOWBENCH FUND
    these are 96-97 heads btw.
    there is already flowbench data floating around for 91-95.
    ever wondered if there is a difference in these heads vs the earlier models or want some numbers for possible cam grinds or porting?
    but never wanted to pull your heads to see?
    then this is for you.
    price....$60. i'll put in 10 plus my gas and time. $50 bux left to make it happen and i will post the results for everyone to have.
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    RE: FLOWBENCH FUND
    got 1 donor for 10 bux off of mymonte down to $40.
      • 13533
      RE: FLOWBENCH FUND
      Moved out of buy/sell/trade
      Do you have a 91-95 head there? I would like to see a comparison using the same bench so we know its a fair comparison. Ill see what kind of money I can get together but yeah, I have 10 bucks for this, 20 if we can get enough to do both heads at once. I will be doing the same on my bench as well and it would be nice to compare the results.
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        RE: FLOWBENCH FUND
        unfortunately i do not have a 91-95 head available but it would be nice. also i forgot to update. some1 else kicked in 10 bux not counting you so counting you it is down to 20.
        there is 1 more person and i am waiting for him to respond again b/c his initial response wasn't very clear to me. if he is down it will be 10 bux.
        EDIT: almost forgot, just hold on to the 10 bux and i will collect the funds if/when i get 5 takers.
        • vsop4me3.1
          • 482
          RE: FLOWBENCH FUND
          I'll put in 10 to help the community.
          I wish 10% of the people on the road knew how to drive
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            RE: FLOWBENCH FUND
            sweet down to the last 10 nice. cmon peeps 1 more.
            • your_I.D.
              • Mar 2005
              • 337
              get'r done!! I'll cover the last $10.00 + the second $10.00 = $20.00
              just get'r done!
              Find out what kind of flowbench there using and what process or steps they do.
              1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                will do. after i find out i will start collections and "get'r done"
                • dohcfiend
                  King Chalupa
                  • Jan 2004
                  • 2351
                  talked to the guy. he is using a superflow 600 flowbench. as far as setup he will use a tube matched to the stock cyinder bore for testing.
                  i will start accepting the $$ now and after i get it all in. i will have the heads tested the following week.
                  my paypal is rhavasi@hotmail.com and it is a personal account so no credit cards.
                  also i will post up who exactly has paid and whatnot. time to "get r done"
                  p.s. if any1 has an extra stock set of 91-93 heads that i could borrow id also like to test the 2 on equal playing grounds as well.
                  • dohcfiend
                    King Chalupa
                    • Jan 2004
                    • 2351
                    thanx vsop4me3.1 and your i.d. 2 down 3 to go.
                    • dohcfiend
                      King Chalupa
                      • Jan 2004
                      • 2351
                      ez112 has dropped 10 bux so that leaves ben and 1 other.
                      • OldSkoolGP
                        That guy over there
                        • 930
                        Well since Ben has my 96 heads for R&D, Im in.
                        • dohcfiend
                          King Chalupa
                          • Jan 2004
                          • 2351
                          k, 1 more left be it ben or matt from my monte.
                            • 13533
                            Sorry I havent checked this thread. Ill have 10 bucks to you this week.
                            • dohcfiend
                              King Chalupa
                              • Jan 2004
                              • 2351
                              kewl, i will have results the following weekend after then. b/c i won't be able to get there until sat and will not be able to pick up until the following sat
