where do I send it?
FLOWBENCH FUND
Originally posted by dohcfiendtalked to the guy. he is using a superflow 600 flowbench. as far as setup he will use a tube matched to the stock cyinder bore for testing.
i will start accepting the $$ now and after i get it all in. i will have the heads tested the following week.
my paypal is rhavasi@hotmail.com and it is a personal account so no credit cards.
also i will post up who exactly has paid and whatnot. time to "get r done"
p.s. if any1 has an extra stock set of 91-93 heads that i could borrow id also like to test the 2 on equal playing grounds as well.1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
Any updates?1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
UPDATE: i talked to the machinist today. he is saying monday now. had some extra work being done on the heads as well as the flowbenching. he said a few of the valveguides have dropped(whatever that means) and i am going to have them all replaced.
on the flowbench he has a set of ford 4 valve heads too and he is waiting for an attachment for the flowbench b/c as of now he is unable to test 4 valve heads until he puts the "bridge" on there to allow him to open both valves at once.The Official Rotating Mass Nazi
well talked to the machinist today be4 work. he is done with the flowbenching al i have to do is arrange pickup.
i did however get him to tell me the important numbers over the phone.
I E
200 170 124
300 196 160
400 252 185
so in going off the numbers that dmotorsports gave be4 the 91-95 outflow the 96-97 on intake but the 96-97 outflow the 91-95 on exhaust(at 400 which doesn't mean shit
) here that are from a 91-95 that are different than the other guy's but at least there is a reference to draw from on the 96-97 heads now.
the machinist also said his flowbench is "stingy" he also remarked that at 200 i/e was 72.9%, 300 i was 81.6% and 400 it was 71.4%.
he remarked that 70% is the "magic number" as far as percentage of exhaust flow vs intake flow. he is now really hyped about working on these heads (which is granted if he wants to make dough) at first he was like "ehh....v6 heads? i'll check them out but i don't know about porting them etc...."
now he wants me to find a junk 96-97 set to cut them up for a cross section. he also wants me to bring him my intake and exhaust manifolds to look at them.
he also made comments about "not necessarily changing valve diameter but the shape" that shit sounds a little too expensive for me.
also commenting about cam timing changes. he said "alot of lift isn't needed, maybe .420" i briefly mentioned to him about the whole interference situation. i really need to actually sit down and talk with him and get some of the things he spouts down on paper.
in closing i believe at least 2 more flowbench test may be necessary on different benches/different set of 96-97 heads to get some real data going.
based on the few quotes i gave, what do u guys think of the machinist? does he sound credibile or just trying to seperate me from my $$$?
p.s. thanx in advance for the advice and for the donations. after i pick up the chart or whatever flowbenches spit out, i will post it.The Official Rotating Mass Nazi
