Engine surges to 3 - 4 k then dies
  • napatiger
    • 490
    I just replaced the steering hydrolic lines, had to drop the engine
    I also had the intake off.
    Should run fine like before.....
    95 MC Z34 Black
    • 13522
    So it surges on start up in park? Brake boosted hooked back up? Time for C4 and a flame thrower?
    • napatiger
      • 490
      yeah, brake booster hose......
      Ben, i just bought some new magnaflows, so the oil cap is on hold.
      95 MC Z34 Black
      • Juglenaut
        • 1130
        If you removed the intake then in other words Time for new intake gaskets.
        I am back
        Mechanical/Service Technican
        • dohcfiend
          King Chalupa
          • Jan 2004
          • 2351
          sounds like either a massive vacuum leak or a massive tps signal problem. codes?
          • z34phoenix
            • Jun 2005
            • 469
            last time i had a vac leak like that turns out i forgot to tighten the bolts from the upper intake manifold to the intermediat arm! i had them hand tight and in the confusion of redoing my FWI at the time i never squezed my hand back in to tighten them... i think it was you dohcfiend that told me to check there... and BamB! it was fixed
