my friend has the classic stretched timing chain issue with his 2006 cts, and i cannot find a single place that sells the chains other than the dealer.
where to buy god damn timing chains for a 2.8/3.6
Question : where to buy god damn timing chains for a 2.8/3.6
\m/ Carlton \m/
99 formula cam only 6.0, 440rwhp, 4500 stall, dana 60
03 silverado hd
sigpicTags: None
Have a look at this link... I'm hopeful you'll find the Timing Chain you need there:Originally posted by 873.1 View Postmy friend has the classic stretched timing chain issue with his 2006 cts, and i cannot find a single place that sells the chains other than the dealer.
I believe there are 3 chains. a main chain, and then 2 secondary chains that run cam to cam on each bank. I have seen the secondary chain for about that price on ebay before so you may want to ask which it is. I am not aware of any aftermarket chains, and the GM set should be from a high quality manufacturer, especially if its reynolds in France (i think that is the name, they make the double rollers for cloyes).Ben
Interesting... a click on that image in the link I showed reads..."Made In France" on the plastic packaging ...so you might get lucky on getting at least some of the parts.Originally posted by SappySE107 View PostI believe there are 3 chains. a main chain, and then 2 secondary chains that run cam to cam on each bank. I have seen the secondary chain for about that price on ebay before so you may want to ask which it is. I am not aware of any aftermarket chains, and the GM set should be from a high quality manufacturer, especially if its reynolds in France (i think that is the name, they make the double rollers for cloyes).
Say Ben...
This is OT here in DOHC...
Have a look at this Milodon "True Double Roller" Timing Set... Does this look like anything that would work in any of our NON-DOHC Roller-Lifter Roller Camshaft 660 or < applications? A Google search on this article header takes you to another site that sells them, too...
http://www.ebay.com/itm/BUICK-V-6-77...item4600cac0e7Last edited by 60dgrzbelow0; 02-26-2012, 04:49 AM.
