3.4 DOHC Turbo
I talked to the guys about the heat shield, and they said if i dont get it, it will melt my hood. The turbo is ceramic coated but I will be adding a turbo jacket. As far as the fuel lines. What did you do? The turbo I am running is a t04e 60 trim with a stage 3 turbine. For now I am going to run the 12.1 vortech fmu and then go back to the turbo shop and get mega squirt put in and tuned. Where can I get those injectors? By the way the shop is CFT. Central Florida Turbo.
Ooooo Soo clean! Im jealous! Should be a Very clean setup when done. I would recomend doing 42.5# injectors and ODBII when you are ready to run. Also i would recommend ceramic coating or heat wrap and a turbo blanket when its done. Makes ALOT of heat! I found some "Fire Sleave" heat sheild that slips over my fuel lines and protects them from heat. (titan motor sports makes a sweet turbo jacket). Also make sure then they add the wastegate that they add it at the Y where it collects or it could get boost creep.
Could you post all the details of your project (turbo size ect...).
SLast edited by RedZMonte; 06-22-2007, 12:11 PM.
Just Wanted To Say Thanks To Timg. He Has Helped Me Through This Whole Project.
If you are thinking of going Boosted I have a Garrett T4, Greddy RS BOV, Greddy Turbo Timer, XSPower 38mm Wastgate w/dump pipe and a vortech 12:1 FMU for sale. $1100 total plus shipping.
I have been running 10 psi on a completely stock motor. I'm at 168k miles now.
Tim
read the other thread below this. a few people have done turbos on the cars.
3.4 DOHC Turbo
I just finished up a 5 speed swap on my 1991 Z34 Lumina. I have to say what a huge diffrence that made. Its like a totaly diffrent car. Now I was really taking a close look at the 3.4 DOHC and it looks like it would not be that hard to put a turbo on this motor. There is a place for coolant lines and oil lines. I guess the big question is is that would this motor hold a turbo the way it is stock. And if it could how much boost could you run on it?? Has anyone ever doen this before to a 3.4 DOHC in a Z34 Lumina???Tags: None
