Custom Ground Cams
    • 9191
    #181
    a lot of production cars are now using a similar method of cam production
    This is how the 3100 and 3400 cams are.
    • your_I.D.
      • Mar 2005
      • 337
      #182
      Crower cams will do regrinds for $100.00 each. They can dup. the W41 profile no problem. Turn around time is 5-7 days.
      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
      1972 3/4 ton 4X4 longbed, built 350, 400 auto, 6\" spring lift, 35\" AT/BFG\'s, dana 60 front axle, 14 bolt gm w/detroit locker 4.56 gears. My ricer smasher
      • slick94prix
        • Jan 2005
        • 201
        #183
        That's the cheapest I've heard yet.
        1992 Miata B Package
        1995 Regal 3100
        1996 Firebird LT1 T56
        • sd_iconoclast
          • 126
          #184
          I talked to Schneider cams, also in San Diego. They did not say how much they wanted, but they also said they could do the DOHC cams.
          • your_I.D.
            • Mar 2005
            • 337
            #185
            Just a note worthy differance in 96 cams and 95 cams: note timing flats.
            96 on left
            • series8217
              • Dec 2004
              • 387
              #186
              My 93 cam flats look like the ones on the left..
                • 13531
                #187
                Yeah, thats backwards, 96 cams are on the right with the single wide flat instead of the 2 smaller flats. Would be nice to know the timing difference though.
                • your_I.D.
                  • Mar 2005
                  • 337
                  #188
                  Originally posted by Gemmer
                  No one to my knowlege has measured the clearance in the cam carriers yet
                  Checked clearance on carriers. Its close. We can't add any height directly to lobe. Lift can only be gained by a smaller lobe base.
                  • your_I.D.
                    • Mar 2005
                    • 337
                    #189
                    I was bored and wanted a little more info on lobe shapes, Intake ver exhaust. So with cam carrier off and upside down. One lifter installed. I pulled out dial indicator and degree wheel(made from old CD and printed degree wheel on a cd label.) Set up dial ind. with a small light cone shaped spring pushing lifter against cam and degree wheel on end of cam. Zeroed degree wheel at highest lift found. Zeroed dial ind.at lowest lift found. Here are my results (degrees are at cam rotation of 360* total. Not crank degrees. Lobe centerline is 0* @ max lift.)
                    EVO: -70* = .000 inches
                    -60* = .004
                    -50* = .055
                    -40* = .148
                    -30* = .244
                    -20* = .312
                    -10* = .357
                    0* = .372
                    +10* = .361
                    +20* = .325
                    +30* = .253
                    +40* = .176
                    +50* = .072
                    +60* = .010
                    EVC +70* = .000
                    IVO: -70* = .000 inches
                    -60* = .010
                    -50* = .050
                    -40* = .133
                    -30* = .220
                    -20* = .284
                    -10* = .340
                    0* = .365
                    +10* = .360
                    +20* = .331
                    +30* = .278
                    +40* = .196
                    +50* = .105
                    +60* = .019
                    IVC +70* = .000
                    One thing I noticed is, the lowest point on cam lobe is not directly opposite lobe's max lift. Theres a .002 drop right before IVO and EVO. If you zero dial ind oppisite lobe's max lift right before IVO or EVO it will drop to -.002 inches. I used the degree reading when dial ind. cam back up to .000 as a referance for valve open. (info above is not an exact measurement but very very close) Someone wanna plot that in to a lobe shape? :P
                    • your_I.D.
                      • Mar 2005
                      • 337
                      #190
                      I can do that. Just need to pickup some more cd labels for another degree wheel. Slide one of each year cams in cam carrier. Setup second dial indicator. Lock cams down with flats. set degree wheels at zero and zero out dial indicators. Note at what degree IVO or EVO starts and compare degrees.
                      Edit: that wont work do to lifter bores are not parallel to each other. So one cam at a time. :P
                      • fieromadman
                        3.4 DOHC fiend.
                        • Feb 2004
                        • 130
                        #191
                        Wow this is kinda depressing that this thread hasn't been updated in so long. Theres alot of good information in here. Anyhow, here is a big update for you.
                        These are the specs for the custom cams that are in two running Fieros and one that is in progress:
                        SPECS ARE AT .050
                        Custom:
                        INTAKE:
                        Lift: 396
                        Duration: 220
                        EXHAUST:
                        Lift: 411
                        Duration: 228
                        Stock:
                        INTAKE:
                        Lift: 369
                        Duration: 205
                        EXHAUST:
                        Lift: 373
                        Duration: 213
                        These are strictly regrinds. He took away from the base circle. They work in the engine without any other modifications. I tested the clearance between a leaked down lifter and the valve stem with plastigauge to make sure there was good pressure there and there was. Of course I did this with the cam carriers bolted on and the cam on that valve stem was positioned on the lifter at the base circle. When the engine is running there is no unusual lifter tap. These were made for a Fiero application with a manual tranny so they are made to rev. And that they do. Good power all the way to 7200 RPM's but they dont really start to wake up untill 4000. The low end is good enough for a Fiero though, and the powerband works well with gearing.
                        I bought the cams through Steve Long Racing cams in California. It was a group buy. My friend at the time Dave Gunsul and Steve came up with the specs for the cams. With the group buy I believe they were 100 dollars a cam.
                        With these additional modifications, one of the engines with these cams installed was dynoed. The modifications are:
                        The engine is a 95 crate motor with about 14,000 miles on it now. It has all stock internals with custom ground cams (cam specs are secret ), 96-97 intake manifold swap, a northstar throttle body, an underdrive pulley, power steering and A/C delete pullies, 180* t-stat, ngk plugs, poly mounts from WCF, custom exhaust, larger injectors (36#), spec stage 2+ clutch, and a custom street tuned chip on the 94-95 (OBD1.5) by sinister performance.
                        It put down:
                        And heres some pictures of the cams and some testing:
                        -Jeff Depies
                        3.4 DOHC- 95 engine, custom intake manifold, custom cams, ported exhaust manifolds, Turbonetics T-62, Haltech standalone, 13.5 psi, air/h20 intercooler... yadda yadda...
                        1987 Fiero, ST lowering springs, KYB's, Clutchnet dual diaphragm 6-puck, custom paint, 18's with falken fk452 225 front Nitto NT05 245 rear. Should be around 450whp...
                        • FieroWannaBe
                          • Mar 2006
                          • 78
                          #192
                          damn wish i could get my hands on some.
                          Something cool coming soon...
                          96 LQ1!
                          • ez112
                            • 258
                            #193
                            I'm sorry but with all you have done ON a manual I'm not impressed with them numbers.
                            There's just so many variables on a manual fiero VS. a W-body automatic. Sure the Fiero will be quick, but on an auto what's going to happen?
                            1999 SVT Lightning
                            1996 Monte Z34 R.I.P.
                            Next BEATER: a C5
                            http://www.fquick.com/ez112
                            • fieromadman
                              3.4 DOHC fiend.
                              • Feb 2004
                              • 130
                              #194
                              It's not my car for one. And for two, what serious modifications does it have? The intake manifolds might give 5 horsepower, the underdrive is worth about 5, and the powersteering is worth 5. That engine that was dynoed is basically stock with cams and a few little tweeks and tuning. Besides that, his "custom" exhaust is nessicary to get the engine in the car, and its not a well designed exhaust system. So you take 15 horsepower off of the 230 that is dynoed to the wheels and you have about 215 to the wheels for an otherwise stock engine. Generally stock engines dyno at 185 generously at the wheels? Thats 30 horsepower from the cams. If you ask me thats nothing to shake a stick at. Also, if you assume 15% loss at the wheels that engine is putting down about 264 horsepower at the crank. So thats about 49 horsepower over stock with the modifications that are done. Obviously there are MANY more variables to that equation, and alot of what I've said are rough estimates, but seriously!
                              Now, for an automatic w-body, would I EVER reccomend these cams? Hell no. They dont generate enough low end, at least not timed straight up. This is why we didnt share specs untill now on the cams, because we dont want everyone to think that this is the one and only aftermarket grind that will work. Obviously that is not true. For a manual Fiero application where you dont need as much low end, these are spectacular! The more supporting mods that are done to this engine and the more the cams will perform too. Ported heads, headers, and ported/custom intake manifold later and realisitcally you are going to be sitting pretty damn well.
                              More than anything I posted that to get peoples brains thinking about doing different grinds so we can do some research and figure out whats best for each application. Now that we have proof that some fairly big regrinds work, and that they are not thousands of dollars, it would be great to try some different specs and see what we come up with. Call Steve Long Racing cams and talk to him about what he can do! Thats what Dave Gunsul did.
                              • ez112
                                • 258
                                #195
                                Yeah good point. I retract my statement.
                                I did call Steve long a long time ago. This was back when I didn't have cores. I asked him about adding low end to the cams because it was going go on an automatic. I knew about these regrinds before and heard that these wouldn't work too good on a heavier automatic. He said he COULD do something about it.
                                Now the part is if he'll still remember me, heh.
                                I don't like my car right now though, so I don't know if this will ever happen....
                                1999 SVT Lightning
                                Next BEATER: a C5
