i know this has been beaten to absolute death, but i figure if we keep it up-eventually there WILL be a living, breathing 3x00 dohc frankenstein monster. i was looking at the article where "3100 mpfi" actually bolted the heads up to the block
http://60degreev6.com/content/34_DOHC_heads_3x00_block
http://60degreev6.com/content/34_DOH...s_3x00_block_0
the big issues that he pointed out were:
1 coolant passages were partially exposed
2 an oil passage or 2 was exposed
3 the stock oiling system doesnt flow enough (stock oiling system doesnt require flow for dohc heads)
4 only 2 of the mounting bolts lined up
Some things that i noticed/thought about:
5 what would you do with the cam in the block?
6 how would you hook the crank to the cams?
7 would the stock dohc intake work & will the ecm work with it?
8 what compression ratio are we looking at with stock 3100/3400/3.1/2.8 pistons
if anyone else has any other issues that theyd like to add then i can add them to the list & we can address them by number just as people think of things (you know, when everyones bored at work, or off work & drinking a a few dozen beers, etc... :P). even if it takes 6 months or a year-if we identify and address these issues 1 by 1 then we may some day have our frankenstein monster. a collective 60degreev6 group effort
