dohc head on a 3x00 block
  • no_doz
    • Sep 2005
    • 912
    i know this has been beaten to absolute death, but i figure if we keep it up-eventually there WILL be a living, breathing 3x00 dohc frankenstein monster. i was looking at the article where "3100 mpfi" actually bolted the heads up to the block
    http://60degreev6.com/content/34_DOHC_heads_3x00_block
    http://60degreev6.com/content/34_DOH...s_3x00_block_0
    the big issues that he pointed out were:
    1 coolant passages were partially exposed
    2 an oil passage or 2 was exposed
    3 the stock oiling system doesnt flow enough (stock oiling system doesnt require flow for dohc heads)
    4 only 2 of the mounting bolts lined up
    Some things that i noticed/thought about:
    5 what would you do with the cam in the block?
    6 how would you hook the crank to the cams?
    7 would the stock dohc intake work & will the ecm work with it?
    8 what compression ratio are we looking at with stock 3100/3400/3.1/2.8 pistons
    if anyone else has any other issues that theyd like to add then i can add them to the list & we can address them by number just as people think of things (you know, when everyones bored at work, or off work & drinking a a few dozen beers, etc... :P). even if it takes 6 months or a year-if we identify and address these issues 1 by 1 then we may some day have our frankenstein monster. a collective 60degreev6 group effort
  • no_doz
    • Sep 2005
    • 912
    keep in mind these are all just ideas
    1: the overhang/gap/whatever you want to call it could be welded & the mouths of the passages widened in the block & head to match to eachother.
    2: oil passages overhung completely-maybe put a nipple on them and pipe them to somewhere else to recieve oil flow as well as return it
    3: higher capacity fuel pump & maybe widening the oil passages in the block? thoughts, opinions, ideas?
    5/6: the stock cam could be completely removed & an "idler gear" or something like that installed-or leave the cam in & just remove the pushrods-then make a gear assembly that bolts in place of stock, but then has a crank pulley just for the dohc like the japper engines have-then you just need to make a cover & get 2 other appropriate sized cam pulleys & voila! you have spinning cams & opening valves.
    • patgizz
      The Plaid Bandit
      • 1071
      while welding on an iron block does not make this very feasible,
      5/6 - use the dummy oil pump drive "cam" from the DOHC and slap on the timing cover and cam drive stuff from it. that's the easy part.
      • no_doz
        • Sep 2005
        • 912
        why is welding on the block not feasible? excessive temps & warping could be avoided if you welded a small amount at a time-or maybe even using a dremel or mill machine-remove a 1 inch sqaure section-fab up a piece-& weld that piece in place slowly & bit by bit so that nothing got warped-one or the other should work if done carefully.
        • no_doz
          • Sep 2005
          • 912
          oh and whats this oil pump dummy drive cam?
            Have you ever tried to weld cast iron?
              Live life 3.7mi at a time
              • 4555
              Cast iron needs to be heated to weld. I know some really good welders that can do it at a few hundred degrees, most need ti to be about 700.
                • 13531
                Fail
                /thread
