Going for 300whp NA
  • 02dohc
    • Sep 2009
    • 105
    #31
    Thank u robet
    Sent from my MB886 using Tapatalk
      Isn't the 3500 crank an interference fit in the 3400 block without major clearancing? If so it would be the same way in the DOHC block.
      I seem to remember reading it wouldn't bolt right in a 3400 block, but I could be wrong.
      • 02dohc
        • Sep 2009
        • 105
        #33
        That and doesnt the 3500 crank also have a timing gear in the middle of the crank that would have to be machined off
          It could be pounded off. It's pressed onto the crank, not machined into it.
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            #35
            Originally posted by 02dohc View Post
            Thank u robet
            didn't know you already had the pistons, just throwing ideas out there to try and help.
              who knows, the 3.4 DOHC block is probably closer to a gen 2 in the interference areas.. it could be worse or better than a 3400... most likely way worse.
              If there is enough meat to make space... then use a 3.6 crank.
                i'm sure it's stronger than the stocker, but any other reason? 3.6 has a stroke of 3.37 compared to the 3.4's 3.31... displacement gained is pretty minimal, though it brings the "3.4" up from 3349cc to 3412cc.
                  just the small stroke gain, I always wanted to put the 3.6 rotating assembly in my 3500. That would have been fun.
                  • ericjon262
                    build it.
                    • Jan 2010
                    • 2218
                    #39
                    it'll bolt in???
                    • caffeine
                      • Jan 2012
                      • 1489
                      #40
                      Well the rods and pistons are a really close match
                      '86 Fiero, 3500, 4-speed
                        I think it was really close in a 3500, ended up at like 14:1 scr. The mains are extremely close, you can check the specs in the download section.
                        • caffeine
                          • Jan 2012
                          • 1489
                          #42
                          Going for 300whp NA
                          I'd be really surprised if the crank could actually fit. But it would be cool. They're built for more power. I do wonder about the pistons though; being cast, can they really be as strong as the 3500 pistons?
                          • 02dohc
                            • Sep 2009
                            • 105
                            #43
                            So hopefully I can get my taxes done today, and order hp tuners in a couple of weeks. The block is at the machine shop getting honed and line honed and overall ready to be rebuilt
                            • ericjon262
                              build it.
                              • Jan 2010
                              • 2218
                              #44
                              food for thought, DHP powrtuner software is still available, all you need is a AVT 838 or AVT 841 cable, and you can flash a PCM. then if you get tiny tuner, you can change most anything you would need.
                              • 02dohc
                                • Sep 2009
                                • 105
                                #45
                                I can't find a dhp power tuner. I would love to have that instead of HP tuners. Can u tune everything including trans shift points with dhp
