READ: my crazy intake idea
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    #46
    well have some data today. idle is livable. it is a little erratic until it warms up then it is smoother than it was be4 the mod. i think some iac adjustments will fix this but it isn't too bad.
    part throttle cruising is very good.
    unfortunately WOT has alot to be desired right now. i mash it and it spits, sputters and belches. it will take of then hesitate and take off again. obviously tuning is needed i am talking to ryan at gmtuners and gathering scanner data for him and hopefully we can iron something out. to me it feels/sounds like the timing is off.
    i am open to suggestions however. i don't think it is the injectors b/c in idle the car revs fine. timing perhaps or maybe not enough air due to velocity losses? perhaps i will have to impliment a restriction be4 the tb to regain velocity? i am also going to take it off and go over it throrughly with liguid gasket to eliminate any possibility of vac leaks.
    there is a 94 in the yard i might have to go to rouge some injectors just to eliminate them however.
    peeps have told me the egr delete isn't to blame the person i talked to said there is no change in behavoir except for a ses light.
    EDIT: i took it off and found 3 vacuum leaks so hopefully that will help.
