OK so here is a List I am looking at doing on my Z. What do you think I can get out of it performance wise after ALL the Upgrades? And they wont be done in the Order Listed just done
Trans Cooler
Synthetic Trans Fluid
Front / Rear Suspension Braces
Poly Bushing Kit (complete)
Front Lowering Springs
Rear Coil Over Kit
12" Brake Upgrade (slotted rotors)
PFC Brake Pads
Under Drive Pulleys (Crank / Water / Alt)
Poly Dog Bone
Upgraded Trans w/ EP Limited Slip Diff
Reworked Intake
Reworked Exh Manifolds
High Flo Cat
2 1/2" Exhaust
Quick Time Exhaust Cut - Out
Lower T-Stat
Cold Air Kit
MSD Wires
MSD Coils
MSD Box
NGK Plugs ?
Reworked Throttle Body
Bigger Injectors
Adjustable Fuel Reg
Nitto Drag Radials (245/50/16)
FWD Torque Arms
Rear Trailing Arms w/ Poly Bushings
Plus alittle Squeeze (NOS)
Plus a few more tricks up my sleeve that I am fabbing up as we speak
Trans Cooler
Rear Coil Over Kit
PFC Brake Pads
Poly Dog Bone
Reworked Intake
High Flo Cat
2 1/2" Exhaust
Lower T-Stat
Cold Air Kit
MSD Wires
MSD Coils
MSD Box
NGK Plugs ?
Bigger Injectors
Adjustable Fuel Reg
FWD Torque Arms
STAY TUNED...................
you know, you can buy the car to go w/ the avatar
