WANT TO DO LIST
  • Zfreak
    • Nov 2004
    • 23
    WANT TO DO LIST
    OK so here is a List I am looking at doing on my Z. What do you think I can get out of it performance wise after ALL the Upgrades? And they wont be done in the Order Listed just done
    Trans Cooler
    Synthetic Trans Fluid
    Front / Rear Suspension Braces
    Poly Bushing Kit (complete)
    Front Lowering Springs
    Rear Coil Over Kit
    12" Brake Upgrade (slotted rotors)
    PFC Brake Pads
    Under Drive Pulleys (Crank / Water / Alt)
    Poly Dog Bone
    Upgraded Trans w/ EP Limited Slip Diff
    Reworked Intake
    Reworked Exh Manifolds
    High Flo Cat
    2 1/2" Exhaust
    Quick Time Exhaust Cut - Out
    Lower T-Stat
    Cold Air Kit
    MSD Wires
    MSD Coils
    MSD Box
    NGK Plugs ?
    Reworked Throttle Body
    Bigger Injectors
    Adjustable Fuel Reg
    Nitto Drag Radials (245/50/16)
    FWD Torque Arms
    Rear Trailing Arms w/ Poly Bushings
    Plus alittle Squeeze (NOS)
    Plus a few more tricks up my sleeve that I am fabbing up as we speak
  • Dave
    • Nov 2003
    • 222
    skip the synthetic trans fluid, and go with type F.
    --Dave.
    • napatiger
      • 490
      can you put the website and prices for those upgrades.
      With all the upgrades you would probably be able to beat stock honda civics
      95 MC Z34 Black
      • dykz34
        • Jan 2004
        • 793
        Where do you plan to get the underdrive pullies? The only one I know of is for the crank...
        You don't need a tranny cooler because your car has one stock.
        • Anonymous
          The nitto tires are worthless becuz an auto 3.4 won't have a problem with spinning tires until it's running sub 15s.
          If you put on a CAI, I would reccomend just using a crank UD pulley. My alternator is already way overworked with the battery in the trunk. So much that I HAD to get an Optima red top in order to start the car.
            • 13530
            Don't worry about the MSD DIS-4 unless you want to spend 300+ for 1-2 mpg and smoother idle. I saw no performance gains with it and got rid of it. Also, I wouldn't bother with the coils either. Oldskool had a set go bad from the factory, and there really isn't anything better than stock GM coils considering their output and longevity.
            You can't really do much to the stock exhaust manifolds either to get you much of a gain, but if you don't want to make headers I guess its your only choice. Honestly, you don't have many performance mods listed that will do a whole lot for you other than the nitrous and possibly the TB. I don't care for the stock plenum at all, which is why I am making a new intake setup for mine. Other than that, your car should handle pretty well with those modifications.
            • dykz34
              • Jan 2004
              • 793
              I say "spray and pray" until you go as fast as you want.
              • Zfreak
                • Nov 2004
                • 23
                In reference to the Pulleys I have fabbed up a Water Pump Pulley Myself,
                and in reference to the MSD I can get all that stuff at 10% over cost . I am also going to Use Type F but use the Red Line Synthetic Type F, been told it would be the best for my situation. I am also now in the stages of doing a Header Set - Up for it. A friend of Mine is a Fab guy in NASCAR, and his specialty is Exhaust Systems. We are also building Killer Motors for us (He also has a Z)We are also planning on making up several different parts, and Pieces for the early
                W-Body's STAY TUNED...................
                • 93GTP
                  • 125
                  Hmmmm....interesting. Keep us posted on this Zfreak. It would be amazing if our dreams of headers were finally made reality. How serious are you about this?
                  • Zfreak
                    • Nov 2004
                    • 23
                    We have ordered all the tubing we believe will we need from Boyce. And we are looking at make some other Hi po W-Body parts as well. I will keep you guys posted as things progress.
                    • Zfreak
                      • Nov 2004
                      • 23
                      Wondering on how my message post wound up being used to sell some one elses parts ?????????????????????????????????????????????????? ???
                        • 13530
                        Because people don't understand that we have a private message system and it is to be used for such occasions. I have cleaned up the off topic posts.
                        • Zfreak
                          • Nov 2004
                          • 23
                          Thanks Ben :P
                          • Anonymous
                            Just to let my opinion get heard. He asked me, I did not start off selling the stuff. He asked me, I said yes, PM me. That was it.
                            As far as the aftermarket parts go. I think the 3 most worthwhile are cams, headers, and an intake manifold. They will argue about the intake, that ours is tuned blah blah blah. But I saw dyno sheets showing otherwise. As for headers, its obvious they will be awesome, if they are built right. Just spend the time and $ to make the set worthwhile, with good specs(ie length, diameter, collector, etc.). They will fit, it just takes some craftiness. Cams, i think for stock or nearly stock motors the guys on desktop dyno have come up with some great specs, showing 60hp gains! But as soon as you start changing the intakes, that changes how the cams should be made. For some reason, I'm guessing the DOHC head and such, our intake manifold totally changes the motors power rnage. So much more than your traditional SBC/pushrod 660.
                            • Crimson Fury
                              dropped your pocket
                              • 111
                              no porting and polishing and or ben's chip? get the p&p done and retard the exhaust cams. btw, nice avatar you know, you can buy the car to go w/ the avatar
                              http://www.w-body.com/forum/viewtopic.php?t=24111
                              Car Domain site!
                              13* cam timing, p&p\'d lower intake, tapered t.b, FFP chip, FFP mount and the 1st lumina w/HUD!!!
